Author Topic: Have 60 in 1 with LL/JAMMA adapter in Ms. Pac. Would MAME upgrade be simple?  (Read 4398 times)
blkdog7
  • Last login:October 07, 2015, 04:43:38 pm
  • Mushroom Kingdom, MA
    • John's Arcade
Hey guys!
I currently have a 60 in 1 board plugged into my Ms. Pac-Man using the Lizard Lick adapter. Installation was painless and easy. Works great and I love it.
However, I wish it had some more vertical classics.
How hard would it be for me to unplug the 60 in 1 and plug-in a J-Pac into the Lizard Lick adapter and run MAME?
This is probably a very broad question. But, assuming I got the front end all working great on my computer and had all the classic vertical games also installed could I easily just take that system and plug it into my Lizard Lick adapter with a J-Pac and that's it??
Any insight or direction would be appreciated.
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
I think the 60 in 1 is in Jamma format.  (i have a couple of 48 in 1 , i think it is the same manufacturer)
here one of my 48 in 1
So i guess your Lizard Lick adapter is just a Jamma convertor for MS Pacman , so on one side you have a JAMMA connector , and you would have just to plug your J-PAC here.
Put a PC ,  an arcadeVGA (or soft15khz) and a front end .
If you can read french i wrote a tutorial for beginer here :
http://www.atomicfe.com/forums/index.php?topic=188.0
blkdog7
    • John's Arcade
Thank you for that! It explains a lot.
