Author Topic: Mamewah custom batchfiles config ?  (Read 3024 times)
MadEditor
  • Last login:May 03, 2015, 10:09:44 am
« on: January 19, 2009, 05:04:25 pm »
Hi
It's been a long time since I configured my cab and I have some trouble now to configure Mamewah for another project.
I've gathered a bunch of old dos games, configured them with dosbox. As i could'nt find a frontend i liked for dosbox, i created a START.BAT file in each game folder. This BAT file call dosbox with the game.
But i want to use only relative PATH ! (This will be on an external HDD and so the drive letter can change)
So to call the game with mamewah i made a DOS.bat like this
CD DOS
cd %1
call start.bat
Now I'm trying to configure that in mamewah...
Here's what i've done ...
### DOS.ini (mamewah v1.63) ###
emulator_title                            OLD DOS GAMES
### List Generation Settings ###
rom_path                                  ..\..\GAMES\DOS
rom_extension
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      ..\..\DOS.BAT "[name]"{dosbox}{safelaunch}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       ..\..\GAMES\DOSsnap
movie_preview_path                        ..\..\GAMES\DOSvideo
movie_artwork_no                          1
enable_fuzzy_search                       1
history_dat_file
history_dat_artwork_no                    1
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                0
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
the "..\..\" trick worked for everything but the command line !!! (artwork are ok, list generate correctly)
For the commandline a get this error :
20/01/2009 0:42:01 Error: 5 Invalid procedure call or argument in MsgExecCmd
It work perfectly if i put this commanline
emulator_commandline                      G:\GAMES\DOS.BAT "[name]"{nodosbox}{nosafelaunch}
But as I said before i want relative path ...
HELP PLEASE :-)
« Last Edit: January 19, 2009, 06:48:53 pm by MadEditor »
MadEditor
Re: Mamewah custom batchfiles config ?
« Reply #1 on: January 19, 2009, 05:18:16 pm »
For the same project, another question i can't find back...
I've named all my game' folders like this : "Name Of The Game (year)(developper name)"
Is there a way to use those information in a mamewah layout ? can it recover the year and developper name in the folder name ?
I know mamewah can filter the (year)(developper name) out in the game listing but i can't remember how ?
Thanx...
« Reply #2 on: January 20, 2009, 06:53:44 am »
Best way to do this is to create shortcuts for each of your dos games...use custom config file(s) if neccessary. An example target:
"C:\Program Files\DOSBox-0.72\dosbox.exe" -noconsole -conf "C:\Program Files\DOSBox-0.72\xwing.conf"
Then point your Mamewah rom_path to a folder you have placed all these shortcuts in. Set the emulator_commandline to 'PC' and away you go. I have a few dos (& PC Windows) games setup this way in one Mamewah list.
MadEditor
« Reply #3 on: January 21, 2009, 03:14:04 pm »
I'd like to avoid the LNK files solutions ... I'not ready creating 400+ shorcuts and .conf files...
I've already made those START.BAT i talked about... At that point the mamewah solution was not in my mind ...
Anyway I want to keep all this portable so there's always the relative path problem, in a lnk there's no way to use a relative path ...
I'm sure there's a solution in which i don't have to go making 400+ files again... .LNK or whatever :-) :-)
Does mamewah absolutely need the drive letter in the emulator commandline ?
I tried like this :
emulator_commandline                      \games\DOS.BAT "[name]"{dosbox}{safelaunch}
and i get the same error:
« Last Edit: January 21, 2009, 03:17:53 pm by MadEditor »
« Reply #4 on: January 22, 2009, 05:00:59 am »
OK I don't blame you!
Yes it does. There is one way around it:
In mamewah.ini, set 'emulator_root_path = g:\games',
Then in your mame.ini file:
emulator_commandline                      [emurootpath]\DOS.BAT "[name]"{dosbox}{safelaunch}
rom_path                                  [emurootpath]\DOS
artwork_image_paths                       [emurootpath]\DOSsnap
movie_preview_path                        [emurootpath]\DOSvideo
etc..
This would still require you manually change the drive letter in emulator_root_path if neccessary, but only this one place would need to be changed.
HTH
MadEditor
« Reply #5 on: January 22, 2009, 09:42:15 am »
Thanks ... I Guess i can live with it :-)
What about those info in the Folder name (year, dev), can mamewah recover them there ?
Otherwise i could easily create a .dat file or something equivalent but what structure should i make ?
And i Know Mamewah can strip off those info when displying the gamelist but i don't remember HOW :-)
MadEditor
« Reply #6 on: February 01, 2009, 09:31:12 am »
I found the filtered list otpion i forgot about... so now i have my list Clean with only the Games Names ...
I still can't find any info as to how recover the year of the game and the Dev of the game...
Is there a way for mamewah to recover those info from the foder name or should i create a file listing those info?
