Author Topic: Test bench PC power supply issues.  (Read 1250 times)
shardian
« on: January 19, 2009, 04:15:58 pm »
This weekend, I started to go thru my box of Gottlieb system 1 cpu boards. I fixed one up for the bench, applied the power leads, and powered on the power supply -- then nothing. I figured the board was dead, so I checked voltages, also nothing. I pulled the leads of the power supply and checked them directly - nothing again! What would cause an AT power supply to power on, yet not supply +5, and -12???
shardian
Re: Test bench PC power supply issues.
« Reply #1 on: January 21, 2009, 02:02:25 pm »
No responses???
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #2 on: January 21, 2009, 02:13:20 pm »
Assuming that the fuse isn't blown:
Shorted output diode ?
Bad PWM Controller IC ?
Bad "Kick Start" Circuit ?
(I just copied those from Randy Fromm's article on the subject ... I haven't actually read it yet).
Working: Not Enough
Projects: Too Many
Progress: None
shardian
« Reply #3 on: January 21, 2009, 02:18:20 pm »
I would assume the fuse isn't blown since the unit powers on (fan runs).
I guess I'll just have to yank a new one.
