Author Topic: Mouse Issues Part Three  (Read 1053 times)
FrizzleFried
    • Idaho Garagecade
« on: January 14, 2009, 01:32:45 pm »
Same issue... still no fix.  Basically left and up move at DOUBLE the rate that down and right move at... I am getting a ton of overspin... it all happened when I moved to Windows XP x64.
I tried changing the poll rate,  but the 3 or 4 programs I tried and the registry addition all didn't work... evidently Win XP x64 is a bit different than x32?
I tried changing ports.
Nothing works.
I found a program that reports a rate when you move the mouse depending on direction...I am getting 60hz down and right and 120hz left and up... that is at the slowest setting with enhance pointer off.  If i turn enhance pointer on I get 120 all directions.  I need 60 all directions it seems because I am getting A TON of over spin.  It's killing Golden Tee... World Class Bowling and other games that you really like to lay in to the TB.
HELP!  I've tried re-installing drivers... I am at my wits end!
Re: Mouse Issues Part Three
« Reply #1 on: January 14, 2009, 01:58:46 pm »
Install linux?
