Author Topic: Sound works on MAMEpc, not not cab speakers? *solved*  (Read 2278 times)
payment_due
  • ---Probation---
  • Last login:August 19, 2012, 11:04:24 pm
  • ---Probation---
« on: January 13, 2009, 06:43:51 pm »
I have a SEGA Megalo 410 cab that has it's own set of (rather robust) speakers.  The machine also has a set of RCA jacks (red/white) to get sound from games like the CPS2 boards.  I know the speakers work because I was able to connect a CPS2 game to it and get perfect sound.  When I connect my MAMEpc, I use a standard HeadPhone Jack to RCA Jack Y-Splitter from RadioShack, and get zero sound.  I checked the volume knob of course, and I get nothing.
I figured maybe the onboard sound card on the system had an issue but if I hook up a set of earphones to it, I get sound.
Does anyone have any idea why this might be happening?
« Last Edit: January 13, 2009, 08:39:10 pm by payment_due »
my MAMEcab progress blog: http://www.lealmedia.com/mame/
sarge
  • Last login:April 27, 2015, 01:42:54 pm
Re: Sound works on MAMEpc, not not cab speakers?
« Reply #1 on: January 13, 2009, 06:59:46 pm »
Well I'm not real sure about your setup but more than likely your motherboard is feeding out a line level signal that would need to be amplified to drive your speakers.
payment_due
  • ---Probation---
  • ---Probation---
« Reply #2 on: January 13, 2009, 07:38:51 pm »
Well, that does make sense but as far as I know the CPS2 pcbs don't have amps, and it worked. Also, I think the cab itself has one inside of it.
I emailed a fellow Megalo owner, I'm waiting on his reply as well.
« Last Edit: January 13, 2009, 07:40:30 pm by payment_due »
payment_due
  • ---Probation---
  • ---Probation---
« Reply #3 on: January 13, 2009, 08:32:43 pm »
Everyone look away please. I don't want to be shamed.
I figured out my 'problem'.  I had forgotten that when I first got the cab, I had removed the marquee which is connected to the speakers. I put it back on one evening and I guess I didn't re-connect the SPEAKER WIRES that power the speakers!
Christ. Now it's working and I get nice and purty sound.
