Author Topic: Ultimate Joystick "sticking"  (Read 1668 times)
Trebeck
  • "The Arcade" - Build #4
« on: January 06, 2009, 07:03:07 pm »
Hey all,
I grabbed six Ultimates from Happ and four work great.  The other two sticks "stick" for a second when going from down to center.  It feels like a plastic part is resisting the movement so I get a ticking noise and resistance when it goes back to center.  As far as I can tell it's the 8 way actuator.  It was in place when I got them from Happ and I haven't changed anything yet.
Anyone else come across this?
mrclean
    • Guscade
Re: Ultimate Joystick "sticking"
« Reply #1 on: January 06, 2009, 08:05:01 pm »
I actually had that tickin' noise you speak of that would speratically come and go on my U360's until i realized that the dust washers were i think interfering with the plexi overlay. Also check do you have access to underneath the panel when its down / crawl under and move it around you might see where its happening.
2,370,650 Gun.Smoke
Trebeck
« Reply #2 on: January 07, 2009, 01:55:27 pm »
Thanks for the reply mrclean,
A great suggestion but not it.  I took off the washers and listened carefully.  Then I spun the actuator and now the right direction sticks. Spun it again and now up sticks.  So it's definitely the actuator.  The thing is when I look at it there doesn't seem to be anything wrong with it.
Anyone else have this problem?
