Author Topic: Wells U3000 - no power up  (Read 2644 times)
jconstanza
  • Last login:April 23, 2009, 02:28:02 pm
« on: January 06, 2009, 12:52:45 pm »
I have a WGM2730 that does not power on. Did a cap kit prior to it not turning on. Checked for broken traces, replaced Q101, also replaced U101. I tried hooking up a light bulb on pins 1 & 3 of CN104 and my bulb does not turn on so I guess I'm pretty sure the problem is in the power supply. Wells doesn't have a troubleshooting guide on their site. Any ideas/help gladly appreciated!
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Wells U3000 - no power up
« Reply #1 on: January 06, 2009, 11:09:54 pm »
normally, a smps isn't terribly difficult to repair.
http://www.wellsgardner.com/pdf/Schematics/U3000_27_inch.pdf
check c117 , c107, c108, r102, r103, r108
also check snubber components  c106,r104, d107
check for loading on secondaries ...
qrz
jconstanza
« Reply #2 on: January 07, 2009, 09:20:55 am »
Can those components possibly be bad even if they tested good or near good, I guess?
qrz
« Reply #3 on: January 07, 2009, 03:36:06 pm »
depending upon the testing method(s).... yes .
ESR ( effective series resistance) and DA (dielectric absorbtion) are two items most cap testers ignore.
in fact, my tester doesn't include DA... the next model up does .
i've had  old 'lytics test ok for value , but excessive esr.
there MUST be min of10v across c107 for the ic to operate.....
qrz
jconstanza
« Reply #4 on: January 07, 2009, 05:16:38 pm »
May I ask what tester you use?
qrz
« Reply #5 on: January 08, 2009, 10:30:09 pm »
sencore lc102...... i think  ?....will need to look   :-[    had it for many years of faithful service !
fyi, the majority of equipment i have is sencore.    and thankfully,  it all paid for itself !!
qrz
