Author Topic: Help: No one-button esc on x-arcade  (Read 1746 times)
dkubarek
  • Last login:February 25, 2011, 01:00:32 am
« on: January 05, 2009, 06:09:41 pm »
Just wired the x-arcade BYOAC kit and it works great but lacks a one button esc for quitting emus. No worries with Mame because there is a two button combo, and you can remap Mame. But my hacked emus want a one button esc to quit. The only option I see is programming another channel of the x-arcade, but then every time I power up the cab I have to switch the controls from its default to the other channel using a button. Not a huge issues but it's for smaller kids. Is there an easier way? I never hacked a program but I'm assuming changing the quit button is out of the question.
Re: Help: No one-button esc on x-arcade
« Reply #1 on: January 05, 2009, 10:17:26 pm »
Can't you just map the emu's 1 button to escape? Isn't that what the x-arcade does when you press 1 + 2 player buttons?
dkubarek
« Reply #2 on: January 06, 2009, 12:00:13 am »
I have the emus mapped to esc but x-arcade doesn't quit them using the key combo. That must just work for Mame because it works fine there, but I have to use an actual escape key to quit out of other emus.
« Reply #3 on: January 06, 2009, 12:11:24 am »
severdhed
  • RIP Dinosaur Hippo
« Reply #4 on: January 06, 2009, 12:28:34 am »
my x-arcade controller has 4 different code sets, that you select by sliding a switch on the back of the unit.  i reprogrammed mine a long time ago and i just leave the switch in that position..it starts up with that config every time...no need for manually switching it at all.  of course my x-arcade is a few years old, so they may have changed it since then...
dkubarek
« Reply #5 on: January 06, 2009, 10:11:50 am »
severhed, yea, I got the 2.0 edition, I guess and that's one of the things you gotta do. No biggie but it would be great for it to just start up and go. I might ditch my other emus anyway. There are plenty of great games in Mame and I would also run into trouble when it came to saving, loading, etc in other emus.
