Author Topic: 2 Questions... Marquee box inside white or silver? Best paint for aluminum?  (Read 1343 times)
Bender
Does anyone know which would reflect more light out of a marquee
Painting the inside white or lining it with a silvery reflective material?
and...
Does anyone know what the best spray paint for an aluminum marquee retainer would be?
Ken Layton
  • Guru
  • Technician
Painting the inside of the marquee area white is best.
ghettodish
  • Last login:October 21, 2017, 03:41:58 pm
Use automotive primer. Any spray-paint should work after that.
note: make sure you use the right color primer as some top-coats are not "solid-body"
white primer for yellow paint, dark gray primer for black paint, etc.
« Last Edit: December 30, 2008, 11:22:52 am by ghettodish »
