Author Topic: Sound Problem - Help a Moron!!! PLeeeeaaasssseee!  (Read 1295 times)
Piss Ant
  • Last login:May 27, 2019, 03:52:51 pm
  • Let's see, what does this wire go to....Pzzzzzt!
« on: June 21, 2003, 04:29:38 pm »
Ok here's the deal - I've got some friends coming over tonight so I'm under a time crunch.  I've just got my new computer up & running.  I installed windows 98 SE fine - Mame fine - I hooked up my new Creative Inspire 2.1 2500 speakers & no sound!!!!! :'( I figure maybe it doesn't have the correct driver installed so I go to creatives website but there is no driver for this set for Windows 98.  I go to my System setup - PCI devices & its got a ? - ? PCI Multimedia Audio device I try to install a driver for it from my Windows 98 disk no luck It can't find one.  Now I know I'm showing my stupidity, however I don't know what to do as this is my 1st time not buying a preconfigured computer.  I tried out an older set of speakers that I know work & they didn't have any sound either.  WTH am I doing wrong.  I'm really desperate, so if anyone got take a moment of their time & help me I'd be forever greatful.  :D
One Totally lost Newbie!!!
Piss Ant
kaustik
  • Last login:June 26, 2003, 05:10:15 pm
Re:Sound Problem - Help a Moron!!! PLeeeeaaasssseee!
« Reply #1 on: June 21, 2003, 04:43:01 pm »
What make is your sound card?  You will need a driver for the sound card not the speakers.
Piss Ant
« Reply #2 on: June 21, 2003, 04:48:46 pm »
It's onboard sound, MB = MSI KT3 V333.
kaustik
« Reply #3 on: June 21, 2003, 04:56:37 pm »
Check out MSI's webpage for the audio drivers.
http://www.msi.com.tw/program/support/driver/dvr/spt_dvr_list.php?part=1&kind=3&CHIP=3&ID=1
The correct driver should be on the CD that came with your motherboard.
Piss Ant
« Reply #4 on: June 21, 2003, 05:13:05 pm »
YEEEESSSSSS!!!! That did it I had previous problem where I had to reinstall RE: video, so why should audio be any different - The Cd that came with the motherboard did it. Thanks (pats Kaustik on the back) Kaustik!
Problem solved - although I'm still a moron.
Piss Ant
