Author Topic: has anyone got a nanao ms8-26SU to display with seperate H and V yet?  (Read 1904 times)
northerngames
  • Trade Count: (+18)
has anyone got a Nanao ms8-26su to display with seperate H and V yet?
I could not get mine to display right seperated and just was wondering if anyone has there's working with non-composite seperate H and V paths.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: has anyone got a nanao ms8-26SU to display with seperate H and V yet?
« Reply #1 on: December 23, 2008, 05:33:05 pm »
i assume this monitor only accepts composite sync- ?
if simply tying the horiz/vert leads together doesn't work , it should be relatively easy to construct a mixer/buffer
stage to interface with the monitor.
qrz
MonMotha
« Reply #2 on: December 23, 2008, 08:05:48 pm »
Grab a 7486, 74LS86, 74S86, or 74HCT86 and XOR the sync inputs together.  You want positive vsync and negative hsync to get negative composite sync.  If you have both positive, you can invert the hsync by using one of the spare XOR gates on the '86 to XOR it with "1" (logic high - tie the other input to +5).  Tie unused inputs on the '86 to GND or +5.  VCC is +5, GND is GND.  The output of the two sync inputs XOR'd together is composite sync at TTL compatible levels, which is what almost all arcade monitors want.
I hate to just connect the two sync outputs together.  While it often does work, it can eventually destroy the sync outputs resulting in malfunction.
