Author Topic: How to make windows shut down after an exit  (Read 1929 times)
Hoagie_one
  • Um....whats a cabinet
« on: June 20, 2003, 02:22:27 pm »
Lets say im using a front end and i exit.  Is thre a way to have the FE automatically run a windows shut down script?
how woudl i so this?
do any FE's already do this?
Syxx
  • Last login:June 25, 2006, 06:36:25 pm
  • Bling Bling
Re:How to make windows shut down after an exit
« Reply #1 on: June 20, 2003, 02:55:36 pm »
Get MAMEWAH, best FE there is, i use it with over 9 EMUs and can even play PC games that dont need keyboard and launch DivX and VCDs from it.
Oh ya and one of the options when exiting is shutdown, or even restart.
check it out. its awesome and i bet the next release will be even cooler.
Hoagie_one
« Reply #2 on: June 20, 2003, 03:16:18 pm »
I want it to have to shut down on exit.  I dont want a choice in the matter at all.  Is that possible
Syxx
  • Bling Bling
« Reply #3 on: June 20, 2003, 05:47:03 pm »
well its not really a hassle all you do it bring up the menu and pick shutdown, its in the same place you would go to exit the frontend so its not difficult to reach.
Hoagie_one
« Reply #4 on: June 20, 2003, 06:04:53 pm »
I just want it to be mandatory.
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
« Reply #5 on: June 20, 2003, 06:14:21 pm »
severeal fe's do this...mine does (exitcomp|true| in cfg\fe.cfg)...dk does...probably more...
you could also use a batch file that launches the fe and the when the fe exits launchers one off those small programs that exit windows...you could also use autoit to make your own...http://www.hiddensoft.com/AutoIt/
peter
Malachai
  • Last login:April 05, 2014, 11:07:00 pm
« Reply #6 on: June 23, 2003, 11:06:13 am »
This should help.  Just start you FE in a .bat file and add the shutdown command after it.  Here's a link to some usefull Win commands: http://www.robvanderwoude.com/shutdown.html
Hope that helps.  It works for me.
