Author Topic: MAME Benchmarking help  (Read 1099 times)
leeluther252
  • Last login:November 13, 2019, 11:16:59 pm
« on: December 16, 2008, 11:06:50 am »
I just built a new pc and overclocked it to a little over 4ghz.  I wanted to benchmark some games on mame but wasnt sure how to do this.  I have been searching for a while and didnt really get the info I was looking for so if some one could walk me through it I would appreciate it.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: MAME Benchmarking help
« Reply #1 on: December 16, 2008, 06:21:14 pm »
Well, you can go through this thread, look at johnIV's mameUI benchmark page, or look at the mame benchmark site.  There are a few small differences in the settings between the three, but pretty much the same.
Quick run: use mame option -str (-seconds_to_run) to have mame run that amount of time; between 1.5 to 2 minutes should be enough.  The rest of the settings, IMO, should then be as follows:
If you want to compare your system vs another's, make sure to match all the settings that other system used.
If you want to test if different games are "runnable" on your system, set all the other settings to what you want to use.
If you want to test how different settings effect your system, run with as many combinations of the settings you want to test as you can.
If you want to compare different mame versions on your system, either make sure the two versions use the same settings, or use as close to the respective versions' default settings.
Robin
Knowledge is Power
