Author Topic: Got my momentary contact pushbuttons...(how to paint em?)  (Read 1408 times)
crashdmj
  • Last login:August 26, 2003, 08:55:42 pm
  • Hulk smash!
    • Best webpage in the Universe!!
« on: June 19, 2003, 08:20:17 pm »
they gave me the wrong color  >:(
So I am gonna spraypaint them....any suggestions on how to make them look good and shiny?
Derek
« Last Edit: June 19, 2003, 10:43:47 pm by crashdmj »
HeadRusch
  • Last login:September 02, 2006, 04:13:30 pm
  • ....Here you are all EQUALLY WORTHLESS...
Re:Got my momentary contact pushbuttons...(how to paint em?)
« Reply #1 on: June 20, 2003, 01:46:26 am »
You can't spraypaint plastic without priming it, unless you go try some of that new FUSION paint from Krylon I think.....that bonds with plastic and leaves a super glossy finish.
how well it will last under repeated button-pressings is another matter.
If they sent you the wrong color, send them back and get the right one.....ps: you realise you'll have to take the buttons apart to paint them, or you're risk gunking up the inner workings of the button right?
".....its like a Koala crapped a rainbow in my brain!"
GoldenBear
  • Last login:March 27, 2004, 07:27:48 pm
  • El Oso de Oro
    • Bearz Inn
« Reply #2 on: June 20, 2003, 03:43:11 am »
Vinyl (SP?) Dye, which you can get at most auto stores works well and doesn't involve any priming.  Might be similar to the Krylon stuff.  Used it to die my keyboard and it doesn't scratch off.  May wanna look around the net for a Vinyl Die mod for exact using instructions.
GoldenBear
reighty
  • Last login:January 21, 2004, 09:11:16 pm
« Reply #3 on: June 20, 2003, 04:56:56 am »
could you vinyl dye the buttons to a look of chrome/silver?  I want to go with the chrome look when SilkStik releases the all metal sticks.
AlanS17
    • AlanS17
« Reply #4 on: June 20, 2003, 09:36:02 am »
They don't come in a silver finish as far as I know. It doesn't work by coating the surface. It works its way into the surface. If you're not starting with white buttons, though, lord only knows what color they might turn if you start mixing the original button color with the new dye color.
Just return them.
