Author Topic: More MameWah - Error and deletes SNAP file...  (Read 1304 times)
gndprx
  • Last login:September 08, 2014, 11:25:49 am
  • nope...
« on: June 19, 2003, 12:09:26 pm »
Haven't found reference to this yet, so I don't know if it's just me or not.
MameWah appears to occasionally give a run time error when exiting a game (any emulator) and then deletes the snap file completely from the snap directory for the emulator.
Any thoughts as to why this happens?  I spent quite some time creating snaps and they are systematically being removed on me.
Thanks in advance!
Re:More MameWah - Error and deletes SNAP file...
« Reply #1 on: June 20, 2003, 10:23:19 am »
That sounds nasty  :-\
The only time MAMEWAH will delete a snap, is if you are using the snapshot renaming feature.  If a snapshot already exists, it will delete it and then rename the new one to this filename.  Otherwise, it will just rename the snap accordingly.
I guess you must be using this feature?  Have you included the full path as well as the filename?
