Author Topic: WG 25k7500 question?  (Read 1802 times)
maddags
  • Last login:March 02, 2011, 03:29:06 pm
« on: December 02, 2008, 06:13:19 pm »
I have a wells gardner 25k7500 in my golden tee 04 cabinet, and was wanting to run mame as well, my questions is that since the monitor is 25Khz should i just replace the monitor with a new one, and will golden tee still be playable on a higher resloution monitor.
or should i go to a tri-monitor cabable of running from 15Khz-31Khz? or go to an LCD monitor?
grantspain
Re: WG 25k7500 question?
« Reply #1 on: December 03, 2008, 06:01:29 pm »
if you still want to run the golden tee fore then i would suggest a tri sync
pretty sure there is a dip to take gtf to 15khz but it looks naff
