Author Topic: De-Greasing Parts  (Read 5318 times)
Neverending Project
    • Arcade Fixer
De-Greasing Parts
« on: December 02, 2008, 10:09:35 am »
I have my yoke (pic below) disassembled and and all the parts are sitting in a bucket of 3-parts water with one-part 409. Does anyone have any other suggestions for getting these things clean? It was some pretty thick grease.
SavannahLion
Re: De-Greasing Parts
« Reply #1 on: December 02, 2008, 11:03:53 am »
WD-40 works pretty well. But it attracts dirt. remove the grease, then wipe down the WD-40 then relube.
Gunshops have a degreaser I've used a couple of times that kicks ass. Can't recall the name of it though.
Check automotive stores, they have scads of products for it.
Depending on the composition of the grease and the materials involved, I've fallen back to everything from 99% alcohol to thinners to (once) gasoline. Take care with the solvents though, don't smoke and don't light a match.
I have never, not once, ever thought to use 409 though. So you got me there.  ;)
In any case, regardless of what solvents I've used. Brushes are your friend, go steal your sisters toothbrush and use that to remove the majority of the grease and grime.  >:D
Ken Layton
  • Guru
  • Technician
« Reply #2 on: December 02, 2008, 01:32:00 pm »
You're gonna rust the hell out of those parts with what you're doing now!
Go to the paint section of your local hardware store and get a can of odorless Mineral Spirits. Buy a few "acid" brushes too while you're there. Mineral spirits will take that grease right off. Then just let the parts dry off on an old towel or rag.
SavannahLion
« Reply #3 on: December 02, 2008, 03:06:23 pm »
I thought you were talking just about the 409. Woah, he's got them in a bucket with water?? I must've not had my coffee yet. Yeah dude, take those parts out and dry them off.
channelmaniac
  • Last login:May 11, 2019, 12:36:18 am
    • Arcadecomponents.com
« Reply #4 on: December 05, 2008, 09:37:50 am »
Castrol makes an automotive engine degreaser that is basically a super concentrated industrial soap. It'll take any grease off and works damn well doing it.
Just make sure you oil up any exposed metal parts with a lightweight machine oil (NOT WD-40) quickly to keep them from rusting. When ready to put it all back you can then use some good quality grease to lube up the gears.
Don't use automotive brake grease. That stuff is cheap and will eat away at some types of plastics.
RJ
Call me a cheap bastard... I learned to fix things to save money... even surface mount soldering...
Visit my website: http://www.arcadecomponents.com
My repair logs are kept at: http://newlifegames.net/nlg/index.php?board=19.0
Neverending Project
    • Arcade Fixer
« Reply #5 on: December 05, 2008, 12:13:55 pm »
The service manual calls for two types of grease for reassembly, but I don't have the parts list so I can't tell what kind of grease they recommend. Can anyone help decipher what type of grease they are referring to? See attached pictures.
Oh, and it appears that the second page calls for lithium grease... what can I use as a substitute for this? I have silicone-based spray lubricant, can that be used anywhere?
Ken Layton
  • Guru
  • Technician
« Reply #6 on: December 05, 2008, 01:15:59 pm »
Just use Lubriplate or white lithium grease available at all auto parts stores.
I use Lubriplate on all coin operated machines where grease is specified.
SavannahLion
« Reply #7 on: December 05, 2008, 01:23:13 pm »
There's no need to substitute Lithium. It's still ridiculously common, but often not in the form that was available twenty years ago. I guess black was more common than white twenty years ago? :dunno But I digress, Lithium can be found in small 2oz tubes for too much $$ or be had from Lowes, HD, automotive stores, or whatever in reasonable quantities.
Ken: Bah! You beat me while I was distracted. Lubriplate? I vaguely recall only ever seeing it in big tubs or buckets. They sell them in more reasonable quantities?
« Last Edit: December 05, 2008, 01:25:23 pm by SavannahLion »
Ken Layton
  • Guru
  • Technician
« Reply #8 on: December 05, 2008, 04:21:30 pm »
Aero Lubriplate is available in 1.75 ounce squeeze tubes. Most arcade game parts houses like Happ Controls, Competitive Products, etc sell it.
Or you can go to www.lubriplate.com and order product id 11386.
If you have an Applied Industrial Technologies branch office in your area, you can buy it from them (www.applied.com).
