Author Topic: NEED INTERIOR SIDE PANEL THAT HOLDS MOTHERBOARD...WILL BUY!  (Read 1374 times)
Ortizimo
  • Last login:July 10, 2024, 07:26:45 pm
  • USAF Retired Veteran (1995-2015)
« on: November 29, 2008, 09:40:03 am »
if anyone is going to throw away or has an extra SIDE PANEL that the motherboard sits in that holds the sound card, etc in place please contact me...I need it bad...thnx!
Sometimes, when it's quiet, I can still hear the monkeys." - Guybrush Threepwood, Mighty Pirate.
spystyle
Re: NEED INTERIOR SIDE PANEL THAT HOLDS MOTHERBOARD...WILL BUY!
« Reply #1 on: August 16, 2011, 05:42:01 pm »
Use an ATX case, drill out rivets and remove material as you see fit, you'll be left with a motherboard holder.
Some cases even have a motherboard tray that is removable :)
I bet there are a pile of ATX cases at your local dump, and often found roadside. Or ask your local computer shop.
