Author Topic: I need to shave a few pieces...  (Read 2840 times)
Gatsu
« on: November 18, 2008, 04:32:58 pm »
I've got a 1 player arcade stick Im working on. The wood is 3/4" MDF.
For the sides and back piece, the plans call for 1 1/2" thick pieces...which means gluing 2 pieces together and filling the seam.
Problem. No matter how many times I measure and measure....and it looks right, when I cut the pieces right after each other...they are never exact. Same measurements....same guide placement. I dunno whats up.
So I glued 2 pieces together to test how it'll work. There's a little extra hangover on one piece so its uneven. Whats the best option to trim down the glued pieces so they are uniform and smooth?
Sandpaper? Router?
Can't use  a table saw because of how the piece has to lay in order for the blade to go all the way through.
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
Re: I need to shave a few pieces...
« Reply #1 on: November 19, 2008, 12:12:54 am »
router with a flush trim bit...definitely easiest & fastest... :cheers:
Chadwick
  • Last login:January 11, 2010, 03:23:34 pm
« Reply #2 on: November 19, 2008, 08:18:17 am »
Seconded; flush trim bit since you already have them cut.  Next time you might consider cutting them together.
