Author Topic: Software probs and Jukebox Arcade..  (Read 3186 times)
xbon
  • Last login:February 16, 2010, 01:33:15 am
« on: November 16, 2008, 01:56:18 am »
I wanted to use Uncle T`s however tried to install it on my pc which had a clean winxp sp3 os installed but nothing but errors so ive downloaded and installed Jukebox Arcade works so far on a few tested folders however i cant get it to display the album art any ideas?
Currently ripping Over 20,000+ Music Cd`s.....
Space Fractal
  • Space Fractal
    • Space Fractal
Re: Software probs and Jukebox Arcade..
« Reply #1 on: November 16, 2008, 05:39:19 am »
did you installed the runtime files from the uncle'T Homepage correctly? what kind of hardware do you use?
Arcade Jukebox is a pure singles based jukebox software and was not desinged to use with albums. Hence there is no coverart support.
look in wiki and checkout for albumbased software.
Lave Laar
  • Last login:January 04, 2022, 06:23:13 am
    • Freeware arcade related programs
« Reply #2 on: November 16, 2008, 05:46:26 am »
I think he's talking about this program SF: http://www.extrastrength.com/jbarcade.php
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #3 on: November 16, 2008, 06:02:02 am »
{edited}
ahh, ok. It seen he have not researched the titlename very much, because arcade jukebox have been used in other much more arcadecab friendly software with named arcade jukebox 8, which does its job.
Arcade Jukebox look like a mouesdriving with typical windows interface, which require high resolution monitor, and hence cant been used in a arcade monitor with much lowere resolution. Due with that I really doesn't like that name, even he used it on his mamecab, which I guess he use LCD + trackball (as I can see). But I do have not tested that yet.
Since its media player based, I guess coverarts need to been named folder.jpg in each folder to been found by the software, like most other software do.....
Arcade Jukebox 8 howover its a great name for the another software I talked about, because its really its job nicely. hence i have not problem with that name, and why I called my software something different (when I created Arcade Music Box)
« Last Edit: November 16, 2008, 06:56:55 am by Space Fractal »
unclet
« Reply #4 on: November 16, 2008, 08:21:18 am »
Did you install the support software first?
I have never heard of WinXP causing people grief .....   :dunno
NebulaSleuth
  • Last login:July 11, 2012, 10:27:33 am
« Reply #5 on: November 17, 2008, 03:57:20 am »
All the album art needs to be in the album folder named folder.jpg.
xbon
« Reply #6 on: November 18, 2008, 02:34:04 am »
Thanks Guys for the replies...
Uncle T yes m8 i did install support software first, im just wondering if its the OS , perhaps the install didnt install properly i may try again later this week...
Much appreciated to those who responded.
xbon
« Reply #7 on: November 21, 2008, 04:50:27 pm »
Today ive reformatted the hd and reinstalled winxp- i then reinstalled sp2..
and installed Uncle T`s and hey presto it works.... no errors.
thanks
