Author Topic: Having trouble with IPAC - Left P1 buttons 1 and 2  (Read 1303 times)
pmilnes
  • Last login:November 09, 2008, 03:15:26 pm
« on: November 09, 2008, 03:05:54 pm »
Hi there,
I need an little help.
On my IPAC, the player 1 left buttons 1 and 2 are a little troublesome:
Sometimes the left p1 button stays in the down position.  When it does this, it releases when I press it again.
Also, the left player p2 button only is pressed every OTHER time I press the button.
When I am in the test mode on the WinIPAC Interactive Panel Designer, and I press these buttons, it sometimes accesses the 'file' menu on the program, and sometimes clicks on the 'Start' menu.
Any ideas?
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
Re: Having trouble with IPAC - Left P1 buttons 1 and 2
« Reply #1 on: November 10, 2008, 02:59:19 am »
It sounds to me like you have Sticky Keys enabled. Do you hear beeps after pressing it several times? Turn it off via Control Panel -> Accessability options.
The P2 button is most likely assigned to Alt, which is why you see the focus shift to the file menu.
Try re-programming the keys to letters and see if all your problems go away.
