Author Topic: Help me critique my CP!  (Read 3105 times)
Cero21
  • Last login:February 23, 2016, 11:04:44 pm
« on: November 02, 2008, 01:43:30 pm »
Hey guys.  Some of you might have seen this before but after letting it sit for a while I decided to redo a bit of it.  I def want to be sure before printing so I decided to sit on it a bit.  Here is the result.  Comments?
Here is the cabinet as it stands now:
Here is the proposed CP:
Same thing with a little extra Gundam in the background:
What do you think?
« Last Edit: November 02, 2008, 01:53:51 pm by Cero21 »
Numbski
  • Last login:November 03, 2020, 01:51:50 pm
    • Numbski
Re: Help me critique my CP!
« Reply #1 on: November 03, 2008, 08:10:48 am »
Looks good to me.  About the only scrutiny I might have is that the Gundam mechs themselves look a bit on the low-res side.  It might have served you to trace those out as vectors and use those instead.  Otherwise, nice work!
Build a man a fire, keep him warm for the night.
Set a man on fire, keep him warm for the rest of his life.
Cero21
« Reply #2 on: November 03, 2008, 06:46:07 pm »
A little bit better?  I ran a sharpening filter on the gundam.
Do you think the one with the middle gundum is better or should I keep it simple without it?
Numbski
    • Numbski
« Reply #3 on: November 04, 2008, 06:40:59 am »
That certainly helps.  I think I'd recommend finding someone to do a "cheap" print of this to get an idea as to whether that translucent gundam will even be visible.  As I've been told - you want to make your primary element(s) pop out from the background.
Cero21
« Reply #4 on: November 12, 2008, 10:56:29 pm »
Thanks for all the commentary Numbski!
I am still very unsure about all my choices so I've been working a little more on it.
Decided on a colour scheme change and simpler text.  How about this?
Also, if you have any suggestions for an image change at the center I'm all ears.
Thanks in advance!
Cero21
« Reply #5 on: November 22, 2008, 09:01:09 pm »
No comments on the new image???
Necroticart
  • Last login:October 19, 2025, 12:07:42 am
  • Welcome to my nightmare
« Reply #6 on: November 23, 2008, 04:31:17 pm »
Nice cp I would keep the old txt looked much better or if you want to keep the plain text I would go with a more fancy font as for the image in the center it looks fine if you want to get a higher res image search on google images
