Author Topic: Need trackball mounting alternatives  (Read 3326 times)
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
« on: June 16, 2003, 09:41:58 pm »
I'm about to receive a Beston/Imperial 3" trackball.  I was seduced by the low price of the refurbished one but wasn't counting on the need for a mounting plate.
Now, Bob Roberts, has them for $12 + $6 shipping = $18.  Ouch!
I'm I out of luck or are there other alternatives?
I'm thinking cutting a 3" hole in a steel plate is probably not an easy task.
Any recommendations?
"The Manuel"
CanStick
  • Last login:May 02, 2004, 12:39:58 pm
    • CanStick Controls
Re:Need trackball mounting alternatives
« Reply #1 on: June 16, 2003, 10:04:47 pm »
Check out this thread:
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=7542;start=msg54260#msg54260
It is the method I am going to be using to mount one in my cab...
Hope this helps!
Terry.
JesterDEV
  • Last login:November 25, 2010, 05:29:21 pm
  • OU812?
    • Jester's Temptation
« Reply #2 on: June 16, 2003, 10:19:25 pm »
I just cut the football (shap of the trackball case) into the MDF and drilled a 3" hole into my lexan. I mounted it directly to the lexan. Lexan is very strong, and might even work like this just fine.. But I decided to put a block of wook under the case just in case.  :)
Ofcouse this only works if you have artwork, or have painted your lexan. Otherwise it would really nasty.
Great big gobs of greasy grimey gopher guts.
TheManuel
« Reply #3 on: June 16, 2003, 11:00:46 pm »
Hope this helps!
Terry.
That's pretty clever.  Do check JesterDEV's suggestion too, tough.  It is even simpler.  I only hope the lexan holds.
"The Manuel"
TheManuel
« Reply #4 on: June 16, 2003, 11:03:11 pm »
You mean to support the weight of the trackball?
Fortunately, as opposed to a joystick, the trackball is not subjected to violent lateral movements, so that seems like it could work.
I think I'm going to try that.
"The Manuel"
CanStick
    • CanStick Controls
« Reply #5 on: June 16, 2003, 11:25:45 pm »
I am actually going to use a combination of the two....I am going to screw it into the wood, and also drill a 3" hole in the lexan and bolt it there as well.  In fact, I may not even bolt it to the lexan so that I have a  clean, "boltless" installation!
JesterDEV
  • OU812?
« Reply #6 on: June 17, 2003, 12:02:48 am »
Yes thats what I ment. I put a block of wooD(not wook) under the trackball so support the weight. The lexan could hold it just fine without the block, but when friends come over things get a bit crazy.
It's never let me down.
« Last Edit: June 17, 2003, 01:29:59 am by JesterDEV »
AlanS17
    • AlanS17
« Reply #7 on: June 17, 2003, 12:46:34 am »
You've never played Golden Tee, have you?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #8 on: June 17, 2003, 02:21:52 am »
I agree, TB's can get a lot of (mostly vertical) pounding.
Robin
Knowledge is Power
mpm32
  • Cheesecake Master
  • Last login:November 20, 2018, 09:25:14 pm
« Reply #9 on: June 17, 2003, 09:51:30 am »
I was going to link you to my method but someone already did.  I have beat the crap put of that trackball mounted the way I described.  Hasn't moved a millimeter.  The key is to be sure that your football shaped hole is sized right.  I made mine so that it's a press fit.  If there was even a little movement between the edge of the wood and the TB housing, I think it would work itself loose.  Note that I also used 1/2" ply for the CP.  I think my method would work in MDF but, I haven't tried it.
Here's a pic of my panel;
« Last Edit: June 17, 2003, 10:00:10 am by mpm32 »
mpm32
  • Cheesecake Master
« Reply #10 on: June 17, 2003, 10:03:21 am »
And here is the debut of my home built Cab - Metal Mame.  Note the metalic theme.  I was waiting on some better pics but anyway here it is. I think I will be getting those new SS sticks.
mpm32
  • Cheesecake Master
« Reply #11 on: June 17, 2003, 10:20:16 am »
That's me pointing.  "if I wiggle that joystick just the right way, someone will bring me another beer"
AlanS17
    • AlanS17
« Reply #12 on: June 17, 2003, 10:42:35 am »
Awesome! Where can I but one of those joysticks? (And who pays for the beer?)
TheManuel
« Reply #13 on: June 17, 2003, 12:14:39 pm »
That's a handy feature to have.  I see you're working on a Rolling Rock there.  For a moment I thought it was a Heineken.
In my case, The panel is 1/2" MDF and I plan to use 1/8" lexan.  It will be a tough call.  Maybe I'll try a combination of your method and JesterDev's as CanStick suggested.
"The Manuel"
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #14 on: June 17, 2003, 03:05:12 pm »
I thought that was the "joystick I broke my knuckle on while playing golden tee"
=P
The cab looks very cool.. more pics and post it in the project annoucements (if it isn't already)
Rampy
mpm32
  • Cheesecake Master
« Reply #15 on: June 17, 2003, 03:40:03 pm »
Not a big golden tee fan so that wasn't a consideration, well, I thought about it but I'd rather have the wico 4-way in there.  I'll post more pics when I get them in the project announcements.  For it's official coming out.
