Author Topic: Dumb question but cant find info  (Read 1765 times)
bigdog1977
  • Last login:June 16, 2009, 01:32:48 am
« on: October 26, 2008, 10:10:16 pm »
What does the symbols stand for after rom titles. I think i figured that (u) means usa and (j) means japan but what is [01] [p1] [h2] [!]
  • [b1] mean??  Im thinking these are the versions, but what should i use? TIA! ???
These arnt the droids your looking for...
testicle187
  • Last login:March 27, 2026, 01:31:48 pm
Re: Dumb question but cant find info
« Reply #1 on: October 26, 2008, 10:22:57 pm »
Beta 1 maybe?  or Build one?
Kevin Mullins
    • Me on Myspace
« Reply #2 on: October 26, 2008, 10:33:20 pm »
What game are you looking at?
Alot of the times the ROM title also includes the original board location on the actual game pcb. Like a grid pattern,  B ---- 1 = B1
But could mean a number of things, sometimes nothing at all except as an identifier.
bigdog1977
« Reply #3 on: October 26, 2008, 10:47:10 pm »
these are sega games.
for instance altered beast
i have roms that say
altered beast (rev00)(JU)
altered beast (rev01)(JU)[H1]
altered beast (rev02)(JU)[!]
altered beast (rev02)(JU)[H1]
altered beast (rev02)(JU)[H2]
altered beast (rev02)(JU)[H3]
stuff like that. Just not sure what REV i should be using and what the heck does all that mean?? LOL
« Reply #4 on: October 26, 2008, 11:12:04 pm »
These are the "Good NES" codes that were standardized by the "Good Utilities":
STANDARD CODES
[a] Alternate
[p] Pirate
[ b] Bad Dump
[t] Trained
[f] Fixed
[T-] OldTranslation
[T+] NewerTranslation
[h] Hack
(-) Unknown Year
  • Overdump
  • [!] Verified Good Dump
    (M#) Multilanguage
    (# of Languages)
    (###) Checksum
    (??k) ROM Size
    ZZZ_ Unclassified
    (Unl) Unlicensed
    COUNTRY CODES
    (1) Japan & Korea
    (4) USA & Brazil NTSC
    (A) Australia
    (J) Japan
    (B) non USA (Genesis)
    (K) Korea
    (C) China
    (NL) Netherlands
    (E) Europe
    (PD) Public Domain
    (F) France
    (S) Spain
    (F) World (Genesis)
    (FC) French Canadian
    (SW) Sweden
    (FN) Finland
    (U) USA
    (G) Germany
    (R) Russia
    (UK) England
    (GR) Greece
    (Unk) Unknown Country
    (HK) Hong Kong
    (I) Italy
    (H) Holland
    (Unl) Unlicensed
    STANDARD CODE NOTES
[a] This is simply an alternate version of a ROM. Many games have been re-released to fix bugs or even to eliminate Game Genie codes (Yes, Nintendo hates that device).
[ b] A bad dump often occurs with an older game or a faulty dumper (bad connection). Another common source of [ b] ROMs is a corrupted upload to a release FTP.
[f] A fixed game has been altered in some way so that it will run better on a copier or emulator.
[h] Something in this ROM is not quite as it should be. Often a hacked ROM simply has a changed header or has been enabled to run in different regions. Other times it could be a release group intro, or just some kind of cheating or funny hack.
  • An overdumped ROM image has more data than is actually in the cart. The extra information means nothing and is removed from the true image.
[t] A trainer is special code which executes before the game is begun. It allows you to access cheats from a menu.
[!] Verified good dump. Thank God for these!
SPECIAL CODE NOTES
**** SNES ****
(BS) These Japanese ROMs were distributed through a satellite system in Japan known as the Broadcast Satellaview. They were transmitted along with a TV show which was connected to the game in some way. These games were only playable during the show, and thus stop after an hour, and many were timed so that only certain time periods were playable.
(ST) The Sufami Turbo device allowed two GameBoy sized carts to be plugged into the SNES. Certain carts combined into new games much like the Sonic & Knuckles lock-on technology by Sega.
(NP) Nintendo Power has been known to release games only available to its subscribers. Most of these ROMs are Japanese, as this practice occured mainly in Japan.
**** Sega Genesis ****
(1) Carts with this code will run on both Japanese and Korean machines.
(4) While this code is technically the same as a (U) code, it is a newer header format and represents that the cart will run on USA and Brazil NTSC machines.
(B) This country code indicates that the cart will run on any non US machine.
[c] This code represents a cart with known faulty checksum routines.
**** GameBoy ****
[BF] Bung released a programmable cartridge compatable with the GameBoy which could hold any data you wished to play. However, many games do not function on
Bung v1.0 carts and have to be 'fixed.'
**** Nintendo (NES) ****
(PC10) The PlayChoice 10 was an arcade unit which played exact copies of NES games in an arcade cabinet. The machines had choice of 10 games to choose from and ran for about 3 minutes on 25 cents.
(VS) The Versus system ran on similar hardware to the PC10 machines, but simply allowed you to play against each other.
Credits
Document written by Psych0phobiA
All codes developed by Cowering for the
Goodxxxx series ROM file renaming utilities.
« Last Edit: October 26, 2008, 11:13:52 pm by DeLuSioNal29 »
bigdog1977
« Reply #5 on: November 01, 2008, 03:06:02 pm »
Delusional,
Godbless you! Thank you for what you do!  :-*
hehehe
`BD
bigredsk10
  • Last login:March 03, 2012, 03:45:20 pm
« Reply #6 on: November 01, 2008, 09:09:58 pm »
So what does REV mean out of curiousity? ....Revision? Version?
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
« Reply #7 on: November 01, 2008, 10:11:20 pm »
The rev is a different revision.  So the higher the number I believe means it would be the newest revision.
