Author Topic: mortal kombat 1 keeps freezing  (Read 1375 times)
subedriver
  • Last login:June 27, 2009, 02:19:05 pm
« on: October 23, 2008, 12:02:18 pm »
So when I play the game it will sort of lock up and the screen goes black and blinks.  If I turn the machine off and then on it comes right back on without a problem.  As far as I know it doesn't have any problems with the roms.  I did put new terminals on the wires that go to the buttons and some of them are too small and I have them shoved on there.  If one of these is loose could it be a ground problem that is causing this?  I'm going to put mame in the cabinet but still a little ways away from it and would like the game to work until then.  It's revision 4.0
subedriver
Re: mortal kombat 1 keeps freezing
« Reply #1 on: October 23, 2008, 12:50:56 pm »
ran it through all the checks and the roms, dipswitches and sound board all check ok
ctozzi
  • Last login:November 24, 2022, 01:05:42 pm
« Reply #2 on: October 23, 2008, 03:47:20 pm »
wonder if you have awire loose causing a short of some sort.
Current Cab's
Dedicated Killer Instinct 1
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
