Author Topic: Trackball mounting help...  (Read 1572 times)
Arm123
  • Last login:March 03, 2025, 11:26:20 am
« on: October 20, 2008, 07:59:57 pm »
I'm just about done with my showcase cabinet 60 in 1 conversion.
I just have to mount my Hap trackballs...  Iv never done this before.  The wiring is no problem, im just having issues with how i am supposed to mount this thing ?
Whats the easiest way ?  I have an overlay that will go over it after its done.  Do i need a mounting plate ? or can i just drill out the wood ?
Arm123
Re: Trackball mounting help...
« Reply #1 on: October 21, 2008, 12:20:03 am »
I was told to make a mounting plate...  but i think that would be a waste of time.
http://groovygamegear.com/webstore/index.php?main_page=product_info&products_id=314
much cheaper and easier  :-)
pinballwizard79
« Reply #2 on: October 21, 2008, 12:21:57 am »
Do you have pics of this arcade?
I like showcases
Singapura
« Reply #3 on: October 21, 2008, 01:27:40 am »
I would like to add a question (sorry for hijacking). How much difference would it make if the CP would not be routered so the plate isn't flush? Could you cover the plate with an overlay?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: October 21, 2008, 04:29:16 pm »
Yup, a mounting plate is the easiest way to go.
No, you don't need to route a place for the plate, but...  the plate is ~1/16" thick, so the top of the plate will be that far above the top of the rest of the CP.  Covering with an overlay won't hide that (and if done wrong you can get wrinkled or torn or warped art work).  Routing the 1/16" off the top of the CP for the plate isn't too hard, and doesn't have to be perfect if you cover it (gaps between plate and CP can be filled with putty).
Robin
Knowledge is Power
Arm123
« Reply #5 on: October 22, 2008, 12:01:06 am »
Yup..  i will also be routing a spot for the trackball plate.  So it sits flush.
Once its done...  I will definetly post pics.
