Author Topic: quick jpac question  (Read 1394 times)
subedriver
  • Last login:June 27, 2009, 02:19:05 pm
quick jpac question
« on: October 19, 2008, 12:17:46 am »
In using a jpac to connect to my arcade monitor with my pc, it will display the correct 15hz right?  It says on ultimarcs website thats it's not for application use.  So would I have to get a arcade vga card?  Would be a temp solution as I plan on putting a tv in it later.
TPB
  • Last login:March 01, 2021, 09:12:52 pm
Re: quick jpac question
« Reply #1 on: October 19, 2008, 01:07:40 am »
To display your video output at 15 khz, you'll either need :
** The ArcadeVGA card, or
** Run the software called "Soft 15khz", written by SailorSat, who's a BYOAC contributor.
There's plenty of threads on Soft 15khz, if you search for them.
Here's a few pages of info., to get you started :
http://wiki.arcadecontrols.com/wiki/Soft-15khz
http://forum.arcadecontrols.com/index.php?PHPSESSID=71c98878b0e50314e6bef2742ec4307a&topic=66402.1120
http://community.arcadeinfo.de/forumdisplay.php?f=142
subedriver
« Reply #2 on: October 20, 2008, 02:29:32 pm »
thanks for th reply will do some more reading on that, sounds like its gonna be the way to go.
