Author Topic: v-hold and arcade VGA  (Read 2088 times)
ikariwarrior
  • Last login:October 16, 2008, 11:52:36 pm
« on: October 16, 2008, 12:01:17 am »
I just got my ArcadeVGA  card, While hooking it up I noticed the harness to my arcade monitor did not have a wire coming from the vertical sync position. I decided to go for it anyways and the screen will not stop scrolling. I tried connecting the vertical sync wire but it did not do anything either. Does anyone know why this is happening?
Jack Burton
Re: v-hold and arcade VGA
« Reply #1 on: October 16, 2008, 01:06:30 am »
You monitor probably has a vertical hold control that needs to be adjusted.  What model of monitor do you have?
andy p
  • Last login:September 16, 2011, 08:14:04 am
« Reply #2 on: October 16, 2008, 06:12:52 am »
What monitor is it?
Are you using a VGA breakout cable?
ikariwarrior
« Reply #3 on: October 16, 2008, 11:55:57 am »
Not sure exactly what kind of monitor it is, but I figured it out. It seems the cable was simply missing the v-sync wire. Not sure why or how, but I managed to make my own breakout cable with the proper connector and voila! Now I need to figure out why the picture is larger than the screen. Also, I can see horizontal lines on the picture that should not be there.
Thanks anyways!
Ummon
  • Trade Count: (+13)
« Reply #4 on: October 17, 2008, 07:52:26 pm »
You're a model for newbies everywhere. Good show. Now for image scan, you can look at my sig for direction.
Yo. Chocolate.
Stephen Hawking
Kevin Mullins
    • Me on Myspace
« Reply #5 on: October 17, 2008, 11:42:02 pm »
Yup, sounds like you still need to adjust the monitor itself. Some good ol' fashion tweaking.
