Author Topic: Call for Wiring Help - Orlando area  (Read 3381 times)
IndyJones1023
  • Last login:February 08, 2003, 08:51:37 am
  • Stuck in the 80s!
    • Emugasm, a MAME cabinet
« on: March 11, 2002, 11:54:22 am »
Now that I have a house with a garage, I will begin construction on my MAME cab. The woodwork and computer setup is not a prob, however, I fear my weakness will be in the wiring of the control panel, trackball, spinner, Opti-Pak, etc. Anyone in the Orlando area comfortable with this stuff? It won't be needed for a while, but I just want to make some contacts to be safe. I have started a web site covering the cab, although nothing is there yet. Check out http://www.westg8.com/emugasm/ for the latest. I'll have some pix and a PDF up tonight or tomorrow. Let me know if you can help!
TL
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
Re: Call for Wiring Help - Orlando area
« Reply #1 on: March 11, 2002, 12:04:58 pm »
The wiring is pretty easy as long as you dont wire up the entire thing and turn it on.  IE, test it out as you go.
Things to remember.  You can daisy chain the ground.  IE, send the ground to a button, then a wire from that button to the next.  But the ground MUST go back to whats controlling it (ie, the ground from an IPac shouldn't go to the ground of a hacked joystick).
Next, how are you doing the spinner/trackball hacks?  Optipac?  hacking a USB mouse?  Each one is different and takes thought.  You mentioned optipac, so I will do a quick assumtion.  The optipac connectiosn and settings will be based on what trackball you have (or what encoders you have).   I think there are three or so different settings that people use to get them going.  Look at the site for info directly for that.  The software if you have more then one trackball is the challenge.
btw, the easiest is probably the buttons/joysticks.  get them working and move to the trackball, then spinner..  No need in trying to get them all working at once.
lightspeed
  • Last login:July 26, 2016, 07:48:35 pm
« Reply #2 on: March 11, 2002, 01:05:37 pm »
Heh - I'm the opposite - the wiring was the easy part!
Is you want to make life real easy, buy a Super-Super Jamma Harness from Bob Roberts and a J-Pac.  Just about everything will be set to go - just attach the wired quick-disconnects to your joy/button switches and your done.
BTW, I live in Clearwater.
