Author Topic: LED questions  (Read 2249 times)
ivwshane
    • My first mame cab! (WIP)
LED questions
« on: October 11, 2008, 10:29:09 pm »
I have a bunch of LED's that I got from an old iphone display and I'm planning on using them to make a marquee light but I have a couple of questions on a couple of things.
First, the LED's seem to have a narrow beam of light, is there a way to widen the beam?
Second, I have two strands of LED's, roughly 16-18 LED's per strand all ran in parallel how do I connect these to a computer power supply?
Currently I can run both strands of LED's off of 3 D cell batteries with no problems.
Would it be just a matter of hooking it up to the red and black wires on a molex connector?
arzoo
  • Last login:March 24, 2026, 08:14:12 am
  • Robots WILL kill you.
    • LEDBlinky
Re: LED questions
« Reply #1 on: October 13, 2008, 08:05:13 am »
If you file the tops of the LEDs flat, you may get better diffusion. It might help if you posted some pics.
Robots will kill you.
Arcade Addiction
fatfingers
  • Got UltraStiks?™
Re: LED questions
« Reply #2 on: October 13, 2008, 09:17:49 am »
You will likely need a resistor or the LEDs will fry from the 5v.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Twinpanther
  • Last login:January 12, 2016, 02:03:51 pm
  • Yukihime
Re: LED questions
« Reply #3 on: October 13, 2008, 09:20:47 am »
Depending on the color of the LED's (Red, Orange, Yellow, Green run about 2.1v while True Green, Blue, White and UV run about 3.4v) you most likely would need a resistor on the negative LED post.  They'll light up without it but most like will burn out much sooner than you'd like.  No expert here by any means but just info I picked up DiYing my own for my reef aquariums.
OMG, where have you guys been all my life?!
fatfingers
  • Got UltraStiks?™
Re: LED questions
« Reply #4 on: October 13, 2008, 10:34:45 am »
Sounds right.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
Re: LED questions
« Reply #5 on: October 14, 2008, 12:16:34 am »
Much sooner meaning straight away IME ;)
Also, since the blue and green appear brighter then the red, calculate the resistor for the red and use that on the other 2, he blue and green will be a bit dimmer but nothing major.
ivwshane
Re: LED questions
« Reply #6 on: October 16, 2008, 01:21:06 pm »
Sorry for replying so late. Here is a pic of the LED (sorry for the low quality).
Would I need a resistor for every LED or just for each string? If i do get a resistor how do I wire it to my pc's power supply?
ivwshane
Re: LED questions
« Reply #7 on: November 07, 2008, 01:49:43 am »
Can anyone answer the above question (how many resisters do I need)?
What type of resister do I need (yes I'm a noob when it comes to this stuff).
fjl
  • Pixels Rule!
Re: LED questions
« Reply #8 on: November 07, 2008, 02:10:58 am »
Back when I used to work with LED's I believe I used to put 1k Ohm resistors for each LED.
Franco B
Re: LED questions
« Reply #9 on: November 07, 2008, 02:34:06 am »
You need to know a few details before you can figure out what resistors to use and how to wire them.
  • Source voltage you are using (either 5v or 12v from your PSU)
  • LED forward voltage (should be somewhere around 3v)
  • LED forward current (should be somewhere around 30mA)
  • The amount of LEDs you wish to light
When you know all of them put them into [this] calculator and it will tell you which resistors you will need and how to wire them (series/parallel/combination).
ivwshane
Re: LED questions
« Reply #10 on: November 07, 2008, 03:11:42 am »
Thanks.
Since these are second hand led's am I screwed if I don't know the values (other than the source voltage)?
