Author Topic: Asteroids monitor Question<fixed> next Q.  (Read 1533 times)
Blue440Duster
  • Last login:October 30, 2008, 08:04:35 pm
« on: October 09, 2008, 08:47:22 pm »
Well I'm thinking about going to look at a asteroids that the owner says "Video doesn't travel to last inch of screen. No scrunching, just shrunk."
Could use some collective wisdom on what causes this, I really don't want to buy it if it's going to require major work as I have plenty of that allready(the ball & chain makes sure of that)
He also says it needs a cap kit, which after a little research on this forum doesn't seem like to big of a job.
« Last Edit: October 22, 2008, 08:13:55 pm by Blue440Duster »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Asteroids
« Reply #1 on: October 10, 2008, 04:20:22 pm »
there are x, y ctls on the game pcb
and on the monitor :  y sizing r79,  x sizing r76
qrz
Blue440Duster
Re: Asteroids
« Reply #2 on: October 11, 2008, 12:44:31 pm »
So it should be just an adjustment? no replacing of parts?
About the cap kit.... I see from research how to do it but I'm not clear as to the reason why to replace them :dunno, as a nubie I guess I need to be enlightened
Thanks for any help.
Blue440Duster
Level42
Re: Asteroids monitor Question
« Reply #3 on: October 11, 2008, 05:00:51 pm »
Electrolytic capacitors (and only those, but usually when we say "caps" we mean those) contain a gel that dries up because of heat and age. The results is that the electrolytic cap starts to loose it's possiblity to "store electricity" (see it as a "temporary" battery).
The heat factor is a major issue on monitors because CRT monitors simply generate a lot of heat. The issue is less on Power Supplies etc. but it's still advisable to replace those too after 25+ years.
Bob Roberts sells kits.
Blue440Duster
Re: Asteroids monitor Question<fixed> next Q.
« Reply #4 on: October 22, 2008, 08:19:07 pm »
O.K. played with the Y control and fixed the shrinkage problem............ one more question, I have a speaker humming issue and sometimes the hum will get loud then the games(asteroids) sound will get quiet..any suggestions?
