Author Topic: Best light Gun for Mame  (Read 11228 times)
MarcC
  • Last login:February 22, 2010, 10:02:16 am
« on: October 08, 2008, 05:19:34 am »
As topic says guys.
Whats the best mame light gun, Mainly want to play the point blank series :D
thatitalian
  • The Revolution Is Coming...
Re: Best light Gun for Mame
« Reply #1 on: October 08, 2008, 05:23:27 am »
Depends on your monitor. What are you using? LCD? CRT? Arcade Monitor?
MarcC
« Reply #2 on: October 08, 2008, 05:27:29 am »
Sorry I should have said that in origianl post.
Its for a cab with a TV using the VGA to SCART mod cable
thatitalian
« Reply #3 on: October 08, 2008, 12:45:36 pm »
I take it it's a CRT tv, not lcd or plasma?
MarcC
« Reply #4 on: October 09, 2008, 03:49:58 am »
Yes its a CRT TV
thatitalian
« Reply #5 on: October 13, 2008, 07:02:44 pm »
You are open to most guns then. The original Namco's (Guncon) are sweet, but very expensive. The Topgun II guns from playasia are also good. Most of the guys on here use them but usually this is because of the fact the work with LCD, as a lot of guns don't. However, they are very good!
You might want to wait a bit and check out the sonic gun system which is due to come out at the end of the year.
