Author Topic: FT: Complete Supergun for a Laptop  (Read 1321 times)
Red
  • Last login:November 07, 2017, 08:37:51 am
« on: October 06, 2008, 10:45:35 pm »
I'm looking to trade my Supergun for a Laptop.  Send me a PM if you're interested in trading.  Thanks.
This custom built Supergun unit is complete with the Supergun unit itself, two 6-Button Controllers, CPS2 Speaker, AC Power Cable and S-Video Cable.
I'm using the CV-04 video chip inside the supergun. It's better than any of the video chips inside a mass produced supergun, such as the MAS Supernova. The CV-04 has high compatibility and crisp composite and s-video. It uses a standard s-video or composite cable and is color adjustable and also outputs in NTSC/PAL.
The controllers and system use the same plastic trim as an arcade and the controllers have a thick protective plexi glass cover just like in the arcade
It has a high quality ATX power supply with an easily accesible and reliable power switch on the back. It also has inline fuse holders. The power supply is already wired to accept all board voltages.
It has Test and Service buttons on main system with Coin and Player Start on the controllers and Button 4 is hooked up like a Neo.
Comes with an actual CPS2 speaker from the big blue cabinets for sound (Pictured on left of Supergun 2 picture).
It also has a decent and sturdy JAMMA harness with a tight fit. Again, better than the other mass produced superguns and has a CPS2/3 kick harness for buttons 4-6.
Here are some pictures:
http://farm4.static.flickr.com/3265/2589002315_ae871d39f0_o.jpg
http://farm4.static.flickr.com/3191/2589002351_4bfd9d1e21_o.jpg
« Last Edit: October 06, 2008, 11:32:22 pm by Red »
