Author Topic: help with a RI-1 rowe jukebox  (Read 2467 times)
dryker
  • Last login:May 09, 2009, 08:59:57 am
« on: October 06, 2008, 06:06:05 pm »
I have a rowe RI-1 and when you push a record sel/ like a-1 they stay in and the
mem/unit in the box just keeps spinning and does not kick out a pin to sel/a record
or stop
Do you thank the coil is bad
Dennis
restezrk@verizon.net
Ken Layton
  • Guru
  • Technician
Re: help with a RI-1 rowe jukebox
« Reply #1 on: October 07, 2008, 10:39:14 am »
Probably a bad relay contact on the keyboard assembly.
dryker
« Reply #2 on: October 07, 2008, 07:14:30 pm »
I thank your right Ken , I got the lid open  and ever thing look read dirty in there.
What should I use to clean up ever thing up in there on the key borad Sw and the
points on relay. I know wd 40 is a no no.
Dennis
Ken Layton
  • Guru
  • Technician
« Reply #3 on: October 07, 2008, 11:43:01 pm »
Go to the auto parts store and buy an automobile ignition points file. You'll use that to file the tarnished/pitted/burned contacts on the open frame relay blade (leaf) switches on the keyboard tray assembly. To properly adjust the switch blade gap, you'll need a switch blade adjuster from a pinball machine parts supplier like www.pbresource.com
Naturally you do this with the power off (machine unplugged from the wall outlet).
