Author Topic: A front end for final burn alpha  (Read 7512 times)
havic626
  • -banned-
  • Last login:August 05, 2012, 05:11:42 am
« on: October 03, 2008, 05:28:17 pm »
does anyone know of a front end that will work for final burn alpha?  ive googled with no success.   ive tried maximus arcade and mala, and those didnt work.  i'd be greatful for any help out there.
Tafoid
  • Last login:February 12, 2025, 04:47:22 am
  • Emulation Devotee
    • MAMELOAD TNG (Front-End)
Re: A front end for final burn alpha
« Reply #1 on: October 03, 2008, 05:57:59 pm »
My front-end does handle recent Final Burn Alpha builds but it only offers limited support as the command-line support for FBA is severely lacking.  If everything is configured properly via the normal interface, ML TNG should be able to find roms/save games (.fs)/input recordings(.fs).  Link is available in my sig.
Nologic
  • Last login:November 21, 2008, 03:22:57 pm
« Reply #2 on: October 03, 2008, 07:01:20 pm »
I'm fairly sure Maximus can run it...and I know Mala certainly can...really any frontend can run it.
I'm not sure how the command line is lacking in FBA...other than maybe a fullscreen switch...which is fixed by setting "Video \ Auto Switch to Fullscreen after loading"
My command line looks like so:
fba.exe [Rom]
Depending on the FE...the aliasing maybe different...but that is what you are looking at.
« Last Edit: October 03, 2008, 07:04:48 pm by Nologic »
"Pinky, you've left the lens cap of your mind on again." - The Brain
