Author Topic: Spray Paint Primer?  (Read 2867 times)
Neverending Project
    • Arcade Fixer
Spray Paint Primer?
« on: September 29, 2008, 10:35:34 am »
I plan on using spray paint as primer to treat my MDF control panel, before applying adhesive-backed vinyl. Some areas may be exposed where the vinyl won't be applied, and I would rather have them flat black then gloss. But I have read that gloss or enamel should be used to prime a surface for CPS adhesion.
So my question is, will flat paint be good enough, or should I use gloss spray paint?
shardian
Re: Spray Paint Primer?
« Reply #1 on: September 29, 2008, 11:09:49 am »
Who told you that gloss is better for adhesion?
Neverending Project
    • Arcade Fixer
« Reply #2 on: September 29, 2008, 11:58:46 am »
Hmm, I don't remember. I thought I read it somewhere, but after a couple of searches I can't seem to find it anywhere. It may have been in the instruction sheet that Scott shipped with the mamemarquees order... I can't really remember.
shardian
« Reply #3 on: September 29, 2008, 01:01:24 pm »
Well gloss surfaces are not good for adhesion. Your CPO will work with a gloss surface, but a roughed up or primered surface is better.
mountain
  • Trade Count: (+9)
  • Last login:March 06, 2026, 07:42:38 am
    • Mountain Jukeboxes
« Reply #4 on: September 30, 2008, 04:47:28 pm »
I have always used automotive sanding primer for MDF surface preparation. It works great for paint and adhesive backed materials. Spray it on and sand a few times and the surface will be as smooth as glass.
Neverending Project
    • Arcade Fixer
« Reply #5 on: October 01, 2008, 11:09:42 am »
I don't have a sprayer, so I was going to just use good ol' canned spray paint (since it is a relatively small job). Could I assume that spray primer is as good as automotive sanding primer? And can I assume for my purpose (adhesive-backed vinyl) that flat spray-paint will work equally well?
mountain
  • Trade Count: (+9)
« Reply #6 on: October 01, 2008, 11:51:18 am »
You can buy it at Lowes and Home depot. It is in a can and costs just a few bucks. The beauty of it is that it dries super fast and sands really well giving you a nice smooth finish.
Neverending Project
    • Arcade Fixer
« Reply #7 on: October 01, 2008, 03:49:53 pm »
Thanks!  :cheers:
