Author Topic: First power up of my JAMMA brand new Monitor scrolling / colors off *Fixed*  (Read 1452 times)
mrclean
    • Guscade
I was very happy to power on my 2nd non MAME arcade cabinet dedicated for the first time and even to see a picture even if it was all screwed up made me happy! I have a brand new Happ 19'' vision pro. the happ wire harness has these colors:
red, green, blue, black, white, yellow
my jamma harness molex connector which doesnt fit the happ monitor anyways only has:
red, greed, blue, black, white, *no yellow*
first powering on it was more or less just red crap that looked like this:
then after fooling around more with the wires it looked as if it was scrolling slanted at a weird angle, mainly red and tough to make out what game it was but you can see here Gun.smoke  :
« Last Edit: September 26, 2008, 10:57:04 am by mrclean »
2,370,650 Gun.Smoke
sarge
  • Last login:April 27, 2015, 01:42:54 pm
It looks as though your sync isn't right.  You should try connecting the white wire of the games harness to the yellow and white wires of your monitor.
mrclean
    • Guscade
ok took it out of the molex connecter and physically twisted both yellow / and white / and other white together.. and low and behold i got a really nice crisp picture ! ! !! however it seems to be slightly shifted to the left how do i correct this ??
2,370,650 Gun.Smoke
sarge
Use the remote adjustment board for the monitor.
mrclean
    • Guscade
I'm sorry not familiar with that can you furthur explain ?
2,370,650 Gun.Smoke
sarge
The little board that is connected to your monitor chassis via the ribbon like cable and has several potentiometers on it that will be labeled hor pos, vert size, vert pos, etc.  If your monitor is new it might still be attached to the side of the monitor frame.
mrclean
    • Guscade
OK I See it, where or what do i turn on that little pcb type board / again sorry for my ignorance as im used to lcd's with on-screen menus
*edit* fixed now on to audio / buttons / coin door.
« Last Edit: September 26, 2008, 10:56:40 am by mrclean »
2,370,650 Gun.Smoke
