Author Topic: uhid. wire up ect.ect.ect?  (Read 1769 times)
G1zm0
  • Last login:October 05, 2020, 06:57:58 am
  • cute by day, devil by night
« on: September 24, 2008, 09:57:53 am »
hi im about to install my uhid ive had for few months now,
has anyone instaled one? its got 6 headers of 9 pins i take it pin 9 is gnd and the others are signal wires?
set up- 2 joysticks, 3 admin buttons, coinmech credit and credit button 2, 12 buttons and trackball (beatson)
so with set1 do i .
connect the joys switches to pins 1 2 3 4, the grounds to ground, the other 4 pins to player buttons 1234, and so on for all remaining items?
and  daisy chain all the grounds and use the software to config the keys?
also how do i do the trackball?
i understand it takes leds to, how do i connect them to it? and do they  just illuminate or can they flash?
and the coin mach does the uhid accept a 12v pulse or just 5v?
** i got harness with it to, but i need another, can i just use floppy cable  for pin header?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: uhid. wire up ect.ect.ect?
« Reply #1 on: September 24, 2008, 01:52:22 pm »
All addressed at the u-hid site (suggest start here).  Also, use the U-CONFIG utility will help show what pin is set to what in/out-put.
Just my 2 cents:
The U-HID is very configurable.  You can set any pin to any input/output (almost).  But use the defaults when you can.
For digital inputs just: decide if you want keyboard or gamepad, use the default gnd and digital input pins, daisy chain the gnds like normal, and set up with U-CONFIG.  But...
The optical interface (ie trackball) is one of the things that is limited to which pins it can use.  So use the U-CONFIG to see which pins you can use before you wire the above digital inputs.
Good luck and let us know how it goes.
Robin
Knowledge is Power
G1zm0
« Reply #2 on: September 24, 2008, 05:18:10 pm »
thanx m8, will do
