Author Topic: VMJ Enabled on Startup  (Read 1078 times)
chris-cy
  • Last login:June 17, 2003, 05:48:39 am
« on: June 13, 2003, 02:50:19 am »
Hi all,
My question is as follows: I'm using win 2k, P4, 256MB pc, with all the necessary jukebox key functions wired using I-pac to buttons, and I put VMJ in windows startup.
VMJ is set up to start in full screen mode.
The problem is that when the computer boots and VMJ loads, is not always enabled. I have to click anywere with the mouse to choose the window in order for it to work.
Can someone think of any solution.
Thanx in advance
spectre
  • -- banned --
  • Last login:April 07, 2004, 08:45:11 am
  • -- banned --
Re:VMJ Enabled on Startup
« Reply #1 on: June 13, 2003, 03:34:23 am »
make a lil mouse button on the back of ur jukebox then... juss tap it after u turn it on? sound like it might work? i dunno...
-- banned --
HeadRusch
  • Last login:September 02, 2006, 04:13:30 pm
  • ....Here you are all EQUALLY WORTHLESS...
« Reply #2 on: June 13, 2003, 11:15:26 am »
Check what you've got loading in the background...maybe something else is loading up and taking "focus" away from your VMJ window........any Taskbar items, TSR's, etc......something else must be loading after VMJ loads and thereby VMJ is not the active window.
".....its like a Koala crapped a rainbow in my brain!"
