Author Topic: The last details of my CP, need your help please.  (Read 3922 times)
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
« on: September 18, 2008, 08:59:50 am »
I am just about ready to pull the trigger on my new control panel and am finalizing the last details. I will be installing two U360s, player 1 & 2 but I also want a dedicated 4 way since I have the room. My question is this, should I install a regular 4 way leaf switch joystick for 4 way play or install another U 360 with a 4 way restrictor plate installed?
I am buying my CP from Mameroom, see link for picture.
http://www.mameroom.com/ClassicController.asp
Thanks.
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
Ginsu Victim
  • Comanche, OK -- USA
Re: The last details of my CP, need your help please.
« Reply #1 on: September 18, 2008, 09:19:32 am »
if you want the most accurate feel, find a Wico 4-way leaf.
Rather than a U360, you should just install a Sanwa JLW set to 4-way. Same stick pretty much, just with microswitches.
Visitor Q
  • The Saw Is Family
« Reply #2 on: September 18, 2008, 09:23:05 am »
Ok… I guess my thoughts was just that I am using two other 360s for player 1 and 2 to have a 3rd one up top with the 4 way plate installed but if it is not going to give me the true 4 way feel, then I will just install a dedicated (true) 4 way as that is my only plans for that stick.
So what is the best 4 way then Sanwa JLW set to 4-way or Wico?
Ginsu Victim
« Reply #3 on: September 18, 2008, 09:38:05 am »
First, I feel that having the U360s eliminates the need for a true 4-way, but I agree on the feel of 4-way diamond restriction.
If you must, I say Wico 4-way (classic!) if you can find it, or Sanwa JLW. Both are great 4-ways.
Visitor Q
  • The Saw Is Family
« Reply #4 on: September 18, 2008, 09:45:09 am »
Yeah, I want that true 4 way feel.
Can you recommend a good spinner?
Ian
  • Last login:February 27, 2026, 11:36:05 pm
Ginsu Victim
« Reply #6 on: September 18, 2008, 09:53:23 am »
Check Ultimarc and GroovyGameGear. Both have excellent spinners that will fit in a 1 1/8" hole and can run via USB.
I made my own, so I can't comment on any beyond hearsay.
Visitor Q
  • The Saw Is Family
Visitor Q
  • The Saw Is Family
« Reply #8 on: September 18, 2008, 11:16:39 am »
Are there true 4 way joysticks or do they all use plates for restriction?
Ginsu Victim
« Reply #9 on: September 18, 2008, 11:26:50 am »
4-way is 4-way. Some sticks do a better job of avoiding diagonals while restricted, but they are all physically restricted, be it by restrictor or a mounting plate with a diamond or cloverleaf hole.
Visitor Q
  • The Saw Is Family
« Reply #10 on: September 18, 2008, 11:34:39 am »
So with that said, Wico 4-way (classic) or a Sanwa JLW will they give me a better feel that a U360 with no plate?
Ginsu Victim
« Reply #11 on: September 18, 2008, 11:40:01 am »
Yeah, for a dedicated 4-way added into your panel, those are both great choices.
Visitor Q
  • The Saw Is Family
« Reply #12 on: September 18, 2008, 11:46:46 am »
See my feeling is this. Even though a U360 can be a 4 way stick, nothing is going to give me that true 4 way feel unless I have a joystick with restrictor plates installed which is why I want a dedicated 4 way. I mean I could install another 360 up top with a plate or just install a 4 way. Does this make sense?
Ginsu Victim
« Reply #13 on: September 18, 2008, 11:55:39 am »
You could do that, but since you'd be using it for 4-way only, it's a waste of money. The JLW is exactly the same, but a lot cheaper since it doesn't have the magnetic sensor.
Visitor Q
  • The Saw Is Family
« Reply #14 on: September 18, 2008, 12:06:09 pm »
Yeah, I guess that was my thinking as well but as far as the other part of the question goes, a joystick with a plate is going to feel better because it is physically limited rather than software limited right?
Ginsu Victim
« Reply #15 on: September 18, 2008, 12:08:29 pm »
Frankly, the U360 is so good in 4-way mode, I don't miss the physical restrcition.
But, yeah, a restricted 4-way will definitely be better than an 8-way switch-based stick without restriction.
Visitor Q
  • The Saw Is Family
« Reply #16 on: September 18, 2008, 12:14:03 pm »
Well like I said, I have the room.
I just figured a true feel would be the best and that is what I have gathered from other users in general. I mean I could always put a fight stick there or a top instead but I figured a dedicated 4 way would get the most use.
Loafmeister
  • Last login:June 03, 2025, 01:49:49 am
« Reply #17 on: September 18, 2008, 01:10:42 pm »
Ok, now you're opening up another can.  If you have the budget for a flightstick, then maybe you should get that, and leave the 4 way to the U360's.  A flightstick with fire button(s) opens up a couple more games that can be played more faithfully...  like Star Wars for example.  Say, do they sell U360's with a fire button on top? (not a hack).
p.s.  keep in mind the ergonomics of your panel versus you monitor. Having a big flight stick right smack in the middle may not be the best spot for it.  Since it's a big panel, I imagine that's all ok, just don't forget to consider everything.
Visitor Q
  • The Saw Is Family
« Reply #18 on: September 18, 2008, 01:39:37 pm »
I am trying to consdier everything here as much as I can.
A flight stick would be cool but I doubt I would play star wars as much as I would play 4 way games. If I got a top fire joystick, it would not be a u360.
Attach is the exact (more or less) setup I am getting with the fluch mount track ball and two U360s. My plans are/ where to make that top center stick dedicated 4 way.
Ginsu Victim
« Reply #19 on: September 18, 2008, 01:48:55 pm »
Nope.
Visitor Q
  • The Saw Is Family
« Reply #20 on: September 18, 2008, 01:51:41 pm »
So anyway, its a top fire up top there, a dedicated 4 way or nothing at all.
Loafmeister
« Reply #21 on: September 18, 2008, 02:27:46 pm »
Put in the dedicated 4 way, that way you can have the full feeling for all the 4way games with the restrictor plates et al.
Visitor Q
  • The Saw Is Family
« Reply #22 on: September 18, 2008, 02:52:26 pm »
As far as the U360s go, any thoughts on using the restrictor plates or harder springs?
Note that the restrictor plates are designed to be a one-off fit, not suitable for regular removal and refitting
We expect most people will find the UltraStik 360 to be perfect for all gaming applications including analog and any variation of digital. But we recognise that some people would prefer a different "feel" to the stick with a mechanical limit on it's movement. So there are three restrictor plates available.
4-8 Way restrictor: This can be fitted in either 4-way or 8-way mode and provides a mechanical limit for those people who prefer this. You can easily adjust from 4 to 8-wy by turning the plate 45 degrees.
Round Restrictor: For those who want to use the stick in full analog and digital programmable mode, but prefer a stick with limited mechanical movement, a round restrictor can be fitted.
Note that fitting the restrictors requires some dismantling so these are a semi-permanent fixture.
Octagonal Restrictor: This can be left in place and used in either 4 or 8-way mode with no need to move the plate between each mode. Octagonal restrictors are used on Sanwa joysticks and have a great following.
Ginsu Victim
« Reply #23 on: September 18, 2008, 03:04:27 pm »
The concensus is circular restrictor with hard springs.
I tried mine standard, and it felt too light and the throw was too long. Added the springs and the round restrictor and it's awesome now.
Visitor Q
  • The Saw Is Family
« Reply #24 on: September 18, 2008, 03:07:19 pm »
Cool, thank you.
Please, anyone else feel free to add input.
Thanks.
Ginsu Victim
« Reply #25 on: September 18, 2008, 03:28:28 pm »
Yeah, I tend to dominate U360 threads. :D
