Author Topic: Problem with Visual Pinball  (Read 2694 times)
CyrusMzRG
  • Last login:July 14, 2019, 07:01:50 pm
« on: September 16, 2008, 04:13:47 pm »
Hi folks, I have a problem when I launch Visual Pinball. I dont know what is happening with this graphic problem.
Anybody can help me with this? this is what I see when I launch any table
I use the ArcadeVGA with arcade monitir in my Machine
thank you
Ginsu Victim
  • Last login:June 28, 2025, 10:45:55 pm
  • Comanche, OK -- USA
Re: Problem with Visual Pinball
« Reply #1 on: September 16, 2008, 04:21:46 pm »
All pinball machines look like that. Have you checked your glasses prescription lately?
Loafmeister
  • Last login:June 03, 2025, 01:49:49 am
« Reply #2 on: September 17, 2008, 02:38:48 pm »
I don't know, it looks to me like you are selecting a video mode within Visual Pinball that is incompatible with your arcadevga.  What resolution do you have it set to in VP?
Tim N.
  • Last login:December 06, 2016, 04:49:21 pm
    • RalphWiggum dot Net
« Reply #3 on: September 17, 2008, 03:45:48 pm »
What is your resolution and color depth set at? Set your resolution to 640x480x16 and see what it looks like... You can try 800x600x16 too, but the 640 setting is probably a safer bet since you are using an arcade monitor...
CyrusMzRG
« Reply #4 on: September 17, 2008, 04:49:19 pm »
I use 640x480x32 bits
thanks all of you
  • Last login:July 11, 2025, 09:17:44 am
« Reply #5 on: September 17, 2008, 06:37:59 pm »
It seems to be displaying the score and flippers just fine, so I doubt that it's the arcade VGA or drivers.  Sounds to me like you have a corrupt install.  Have you tried re-installing a new version?  Or an earlier version (any version that is not the same as your current version).
~ D
Loafmeister
« Reply #6 on: September 17, 2008, 07:44:25 pm »
Also do you get this for any tables?
