Author Topic: Could an Arcade monitor be put into a TV case?  (Read 2381 times)
Jack Burton
« on: September 16, 2008, 02:34:04 am »
Does anybody know whether or not an arcade monitor would fit into an old tv case, maybe one of those old RCA floor models?
I'm looking to have a "TV" to play NES and SNES games on their native resolutions and I just happen to have a 25" arcade monitor setting around doing nothing.
I'm pretty sure as long as the mounts line up it would be an easy switch.  Adding in a power supply and switch shouldn't be a problem either, I could probably even hack it to use the TV's power button.
Has anybody here done something like this?
« Last Edit: September 16, 2008, 02:36:53 am by megaultrasuper »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Could an Arcade monitor be put into a TV case?
« Reply #1 on: September 16, 2008, 10:04:07 pm »
some monitors used zenith and rca crts. so yes, if u wanted to do that.
  the potential problem might be matching the bezel to the crt curvature .
 so, suggest using a matching brand cabinet
who made ur crt ?
qrz
Jack Burton
« Reply #2 on: September 16, 2008, 11:30:17 pm »
Mine is a wells gardner that came in a Mortal Kombat cabinet.  I'll have to wait until the weekend when I can get to it to tell you the model number.
Ummon
  • Trade Count: (+13)
« Reply #3 on: September 17, 2008, 05:52:03 pm »
I've thought of doing this with a flat screen CRT. Problem was I couldn't find a dead flat CRT TV. Not yet.
Yo. Chocolate.
Stephen Hawking
qrz
« Reply #4 on: September 18, 2008, 04:24:21 pm »
Ummon,
i have some flat 24" crt's  i could part with - no chassis .  interested ??
qrz
StephenH
« Reply #5 on: September 19, 2008, 04:30:28 am »
I am not sure if it would fit.
I just wanted to let you know that you can get 15Khz RGB out of a Super NES if you wanted to connect it to your arcade monitor.
ToplessZ
  • Last login:December 08, 2018, 09:55:34 pm
« Reply #6 on: September 19, 2008, 11:30:59 am »
Dont forget to use an isolation transformer, fi your using an arcade chassis.
Ummon
« Reply #7 on: September 19, 2008, 07:48:36 pm »
Ummon,
qrz
Thanks, but it would need to be "27, and in any case I'm preferring something local.
Yo. Chocolate.
Stephen Hawking
