Author Topic: Stella and Project64 makes Mala layout move, Fixed!  (Read 5210 times)
Bender
« on: September 13, 2008, 12:13:02 am »
when I exit(quit)a game with "exit hook" or through the stella GUI it makes Mala disappear(*EDIT it actually just moved the layout off screen), it is still running but I can only see my desktop
any Ideas?
I have to ctr alt delete out and restart Mala to get back in, so weird
I have zsnes running and it works fine
« Last Edit: September 16, 2008, 12:40:18 am by Bender »
SGT
  • Last login:March 04, 2026, 07:39:32 pm
Re: stella makes Mala disappear
« Reply #1 on: September 13, 2008, 11:55:00 am »
Edit:  Sorry I was too stupid to see that you said you had already tried it through the Stella GUI.
With Mala or any front end for that matter, it is always best to re-configure the emulator to use the key you want to quit the emulator.  You only want to use the exit hook if the emulator does not have a way to reconfigure the exit key.
With that said, I would not use the Exit Hook in Mala for Stella.  Just start Stella up manually (not using Mala).  Then goto:
Options>Input Settings>Emul Events>Quit>Map
...Then choose the key you want to use to quit (ESC or whatever....)
« Last Edit: September 13, 2008, 01:10:08 pm by SGT »
Bender
« Reply #2 on: September 13, 2008, 12:01:15 pm »
Actually I tried that first
still same result
SGT
« Reply #3 on: September 13, 2008, 12:12:49 pm »
It works great for me.  There must be some other issue going on.
SGT
« Reply #4 on: September 13, 2008, 12:15:49 pm »
When you Ctrl-Alt-Delete to get out, is Stella running in the background and you have to end that?
Bender
« Reply #5 on: September 13, 2008, 12:26:05 pm »
No
Bender
« Reply #6 on: September 13, 2008, 09:06:58 pm »
OK update here
I changed the screen resolution in Stella and now I get my Mala layout back, BUT the layout is all moved around?
It's defiantly a resolution or refresh problem
getting closer to fixing it anyway
Bender
« Reply #7 on: September 13, 2008, 09:12:40 pm »
OK
I adjusted the screen resolution in stella to match my screen resolution in Mala and now it work
Except that stella is now not fullscreen
I've tried Multisync
still nothing
any Idea of how to get a larger version of stella without losing my layout in Mala?
« Last Edit: September 13, 2008, 10:00:06 pm by Bender »
XyloSesame
  • Last login:September 17, 2024, 05:57:04 pm
  • the creepy prince guy...
    • The Nightingale Theater
« Reply #8 on: September 15, 2008, 11:34:29 am »
OK
still nothing
I had the same problem with Stella -- Don't know if you've tried this or not, but it worked for me...
MaLa > GUI > Game Start/Quit > Reorder layout after game quit <--- Should be enabled (checked)
** Edit **
I just checked my config and realized I have res set in the Stella cmd line which would affect the display, NOT reordering as mentioned above (I think...)
My cmd in MaLa has -fullscreen 1 -fullres 1024x768 -video gl
I'm using an LCD with MaLa at 1024 so I had to set the res of Stella at 1024 to fix the layout shifting problem.
« Last Edit: September 15, 2008, 01:00:04 pm by XyloSesame »
Bender
Re: stella makes Mala layout move
« Reply #9 on: September 15, 2008, 09:29:41 pm »
I Finally got stella to work by setting the resolution in stella to match mala and that seemed to work now I'm having the same problem with project64
I set the resolution in there and it shifts the layout in mala even thought the resolution for full screen is the same :banghead:
« Last Edit: September 16, 2008, 12:41:45 am by Bender »
Bender
« Reply #10 on: September 16, 2008, 12:34:32 am »
ok this too is a resolution problem
in project64 1.7 in the graphics config menu there is something called a glide wrapper that has to be set to the same resolution as mala and bingo it now this works too! ;D
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: Stella and Project64 makes Mala layout move, Fixed!
« Reply #11 on: September 16, 2008, 12:42:01 am »
