Author Topic: Wire 2 joys on player 1?  (Read 1808 times)
georgemcfly
  • Last login:April 22, 2009, 02:35:53 pm
« on: September 12, 2008, 12:02:35 pm »
When you wire in a 4 way joy and 2 buttons, are they just spliced into the player 1 up/down/left/right and 1/2 buttons? I was planning on going with a small 2 player layout but wanted a setup for old games as well. If its that easy, I'm modding my CP layout.
Hoopz
  • Last login:April 26, 2026, 09:04:18 pm
  • Intellivision Rocks!
Re: Wire 2 joys on player 1?
« Reply #1 on: September 12, 2008, 12:29:32 pm »
You don't need to splice the wires, but you can easily connect two wires to the inputs for P1 Joy and buttons.  It's a simple step to take.
georgemcfly
« Reply #2 on: September 12, 2008, 01:01:55 pm »
wire both wires into the input on my ipac2 for the shared ones?
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
« Reply #3 on: September 12, 2008, 01:24:24 pm »
yes. I did that with some push buttons.
TAG
  • Last login:May 23, 2014, 05:52:05 pm
« Reply #4 on: September 12, 2008, 01:36:28 pm »
Or I believe that you can run wires between the shared connections, and just attach one to the IPAC, rather than wiring each separately to the IPAC.
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
-- Dirk Gently
miles2912
« Reply #5 on: September 12, 2008, 02:32:52 pm »
I ran mine to a common block - they have them at radio shack and then ran a wire to the ipac.  A lot of different ways to do this.
Hoopz
« Reply #6 on: September 12, 2008, 02:40:56 pm »
Yep.  I think it's the easiest way.  Simply putting two wires into the screw terminals saves time/effort.  No splicing, combining etc.  Just pop em in, screw them down, and start playing!
georgemcfly
« Reply #7 on: September 12, 2008, 02:49:39 pm »
awesomeness. Now I have no reason not to add spinner and 4way.
