Author Topic: Running wires up an existing small hole in ceiling????  (Read 1676 times)
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
« on: September 11, 2008, 02:43:06 pm »
So i have wires running up a hole in my basement ceiling to a bedroom wall. The hole is just big enough for the wires I have now. What type of small tool could i use to make the hole bigger without disturbing the wires. If I use a drill it will suck the wires into the spin and shred them up.
shardian
Re: Running wires up an existing small hole in ceiling????
« Reply #1 on: September 11, 2008, 03:02:18 pm »
Box cutter or drywall saw.
punxrus
  • Last login:July 07, 2009, 03:27:53 pm
  • It's business time...
    • Home Sweet Home...
« Reply #2 on: September 11, 2008, 03:21:52 pm »
Variable speed Dremel...best bet besides a drywall saw...
Dude...Wait...What?!
« Reply #3 on: September 11, 2008, 03:24:31 pm »
Specify the wire type... that's pretty damn important before you go cutting around them.
punxrus
« Reply #4 on: September 11, 2008, 03:35:11 pm »
Yeah...good point! Always forget about that part!
billf
  • Last login:September 14, 2022, 05:53:05 pm
  • Why ya dog-gone crazy idgit!
« Reply #5 on: September 11, 2008, 08:39:46 pm »
Widening out an existing hole may be tough depending on what kind of wire is there currently.  How about drilling a small hole right next to the current one to verify the existing wires are not in the way, then widen the new hole to the size you require.
protokatie
« Reply #6 on: September 12, 2008, 04:35:44 am »
Outside of safety (IE dont go cutting around mains lines), but there is also an issue of cross-talk. Too many "moderatly" shielded data cables running next to each other can cause problems that down the road may be hard to diagnose. I'd go with billf and make a second hole, so you have some distance between the wires. (Also the two holes can be combined at a latter point in time if need be)
