Author Topic: One tool to rule them all?  (Read 4885 times)
glonq
  • Last login:September 09, 2009, 02:24:24 pm
« on: September 11, 2008, 01:55:24 am »
I'd like to build a bartop.  I don't think I have the right tools for the job yet, but I don't want to buy a crapload of tools right now.  Is a router the most versatile thing I can get?
Right now, I have these:
  • A circular saw (too clumsy for most cab work)
  • A dremel (too small for most cab work)
  • A power drill (for pilot holes, button/joystick holes)
  • A chop saw (useless for cabs?)
I know a router will be good for edges, holes, the t-molding slot, and more.  Can I use it to cut the outline of my cab from 3/4" MDF, or do I need to buy a jigsaw for that?
joeks
  • Last login:July 13, 2023, 02:14:29 pm
Re: One tool to rule them all?
« Reply #1 on: September 11, 2008, 02:40:47 am »
i am just finishing building my first cab, but from what i know,
you have to use the jigsaw at least for the first sidepanel. the second panel you can do with the router and "copy"-bit.. don't know it's exact name, but with that bit you can trace and cut-out the second panel perfectly.
to be honest, i mostly used my jigsaw and circular saw for straight cuts, and than sand a lot.
but you can better use a router for straight lines from what i have seen / heard.
a router also makes very nice circular holes and speaker slots from what i have seen.
but i am going to use my router for the first time today or tomorrow when i am cutting the t-molding slot.
a little scared of the router :)
good luck!
Blanka
« Reply #2 on: September 11, 2008, 07:07:22 am »
What about making a CAD file and have the whole stack of crap CNC'ed  :applaud:?
The only tool doing all!
Table-saw, hand-saw and router is the most versatile/precise set when DIY at home. For tiny things a fret-saw can be a marvelous piece of equipment too (forget that kids-hobby-club-christmastree-sawing nightmares)
For the bulk . It is not very practical to buy yourself, but boy find yourself a woodworking shop where they have it. Its worth one Million donkey kong points! Did I say 1/5th mm and 1/10th degree angular precision! Try that with your hand-gear.
For the sharp angles, those last cm's a table-saw cannot reach. It is better than a jigsaw for these last bits as it is wanker-arm-operated, so no going too far, the width of the cut is more simalar to the table saw blade and the cut is very straight.
For weird shape joystick/trackball holes.
For large round holes (speakers/trackball), curves and T-molding.
« Last Edit: September 11, 2008, 07:25:36 am by Blanka »
« Reply #3 on: September 11, 2008, 08:57:47 am »
You can do the straight cuts for a cab just fine with a circular saw and a straightedge guide (home made or not).  Lots of people do it all the time without having a tablesaw... in fact, for an inexperienced operator, cutting full sheets on a tablesaw is just dangerous.
Blanka
« Reply #4 on: September 11, 2008, 10:18:55 am »
There's always that man willing to help..... even easier!
Chadwick
  • Last login:January 11, 2010, 03:23:34 pm
« Reply #5 on: September 13, 2008, 12:38:46 am »
The DeWalt Track Saw: (called the plunge saw in Europe, no info for it on the US site yet)
http://www.dewalt.co.uk/ontrack/UK/index.html (turn down your volume low before you click)
I got to play around with one at the International Woodworking Fair a couple weeks ago.  This is one sick tool.  Comes out in November for around $400 the guy said.  I'm going to buy one as soon as they are available and plan to write up a nice review.
« Last Edit: September 13, 2008, 12:41:47 am by Chadwick »
