Author Topic: Joystick Q's  (Read 1816 times)
crashdmj
  • Last login:August 26, 2003, 08:55:42 pm
  • Hulk smash!
    • Best webpage in the Universe!!
Joystick Q's
« on: June 11, 2003, 09:54:05 pm »
Can you change the P360's handle to say a ball-top?
Also is there a way to make the t-stick springs looser?
Derek
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Joystick Q's
« Reply #1 on: June 11, 2003, 10:34:33 pm »
Derek
yes you can... I believe if you use the 4" length wico ball tops shafts they fit very well (i'd have to dig up an old thread to show you) (or get the replacements from that ebay guy)
you can probably replace or stretch out the spring in the t-stick I imagine... to adjust the feel...
*shrug*
rampy
crashdmj
  • Hulk smash!
Re:Joystick Q's
« Reply #2 on: June 11, 2003, 10:40:03 pm »
What ebay guy!  ;D
Wouldn't stretching out the spring make it tenser?
Derek
rampy
  • *shrug*
Re:Joystick Q's
« Reply #3 on: June 11, 2003, 10:42:32 pm »
What ebay guy!  ;D
Derek
Got me there (but it *would* change the feel, no?) I guess you could cut some of the length of the spring then...
digging up link... *BAM!* linkage to balltop discussion
rampy
EDIT: here's another thread of interest and although it's talking about the e-stick discussion on replacing stiff spring
while we're discussing this... oscar -> can one use 3.5 inch ball tops in p360's instead of the 4" ers?
« Last Edit: June 11, 2003, 10:50:47 pm by rampy »
crashdmj
  • Hulk smash!
Re:Joystick Q's
« Reply #4 on: June 11, 2003, 10:55:43 pm »
Thanks Rampy, now I have some research to do.
Derek
edit* And Oscar if you can use the 3.5 or the 4" ball tops, which do you prefer and which feels more precise.
Derek
« Last Edit: June 11, 2003, 10:59:20 pm by crashdmj »
OSCAR
    • Oscar Controls
Re:Joystick Q's
« Reply #5 on: June 11, 2003, 11:13:48 pm »
The only real difference between the 4" & 3.5" handles is that the 4" handles are better suited for wood control panels.  You could get away with the 3.5" handles in a wood control panel, but even after routing out for a 3/8" mounting depth they will probably be a bit on the stubby side, kinda like a Pac-Man stick.  Performance-wise, I don't think there is much difference... unless the short 3.5" stick feels uncomfortable to you, then that may hamper your action on it.  Personally, I wouldn't use the 3.5" sticks for a wood control panel on a multi-purpose cabinet where you will be playing a variety of different games.
crashdmj
  • Hulk smash!
Re:Joystick Q's
« Reply #6 on: June 12, 2003, 12:16:47 am »
Ok I emailed the guy from n2new@aol.com, and he will sell me 4 Wico 4" ball-top handles (can't wait). I ordered one red, blue, green and yellow to match my buttons. Now I just need to decide on a marquee and CP artwork hmmm....
Thanks Oscar and Rampy
edit* So it's basically just put the Wico shafts in instead of the P360s and play Oscar?
« Last Edit: June 12, 2003, 01:42:14 am by crashdmj »
Grasshopper
Re:Joystick Q's
« Reply #7 on: June 12, 2003, 02:34:20 pm »
As Oscar says the 4" handles are generally preferable if you're mounting in wood. However if you increase the length of a joystick's shaft you also increase its throw slightly. And this will also cause the spring (or grommet) to feel lighter. So a 3.5" shaft will feel very slightly different to a 4" one.
