Author Topic: K7000 neck board help!!!!  (Read 5036 times)
Oni2382
  • Last login:December 07, 2015, 11:00:36 pm
« on: September 06, 2008, 11:26:15 pm »
What's up everyone?.
I need a little help with the cap kit I'm doing on the WGK7000 chassis.  On the neck board I am replacing Cap C204. However, on the board their is no distinction for polarity (+  or -)  could SOMEONE please point me in the correct direction. Every other cap on the main chassis has the + marked except C204 one the neck board.  I downloaded the PDF manual and that has no distinction either. I managed to replace the other caps successfully and I won't put this last cap in until I know the correct placement. I carelessly removed the cap without looking at how it was oriented, a valuable lesson learned. Thanks for any and all help.
XBL:Mykungfooizgood
PSN: Mykungfooizgud
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: K7000 neck board help!!!!
« Reply #1 on: September 06, 2008, 11:43:06 pm »
take a quick look at the foil side of the board .
the neg side of the cap connects to gnd .
 the pos side will have a trace to p202 pin 3 and to a common side of R207,8,9.
the cap is the rgb decoupling/filter for the driver pwr supply
schematic here :   http://jstookey.com/arcade/WG_25k7191/k7191-complete_lg_.jpg
qrz
Oni2382
« Reply #2 on: September 08, 2008, 09:32:28 am »
Your a Life saver thanks. I owe you one  :cheers:
XBL:Mykungfooizgood
PSN: Mykungfooizgud
Ken Layton
  • Guru
  • Technician
« Reply #3 on: September 08, 2008, 10:24:15 am »
Early production k7000 did not have an electrolytic capacitor there. It was a ceramic disc type. The manuals didn't show it since it was one of those "production improvements" Wells is known for. The only place I was able to find it shown on a schematic was the 25k7191 schematic.
qrz
« Reply #4 on: September 12, 2008, 10:33:06 pm »
and change the ceramic cap whenever it is encountered...... ;)
qrz
