Author Topic: Hacking a keyboard  (Read 1257 times)
RedSquirrel
  • Last login:September 18, 2003, 12:07:55 pm
Hacking a keyboard
« on: June 11, 2003, 01:40:03 pm »
Okay, thinking of ways to turn the PC off without opening the case and shutting down via keyboard.
I have one of these keyboards with a bunch of buttons on and one of them is a shut down button.
I could wire it from the keyboard to the cab side etc. However I dont really want a long wire going from the keyboard to the cab if i remove the keyboard and place it on my lap for example.
Or possible could i keep the keyboard in there (hack other buttons too if i want) and just use a USB keyboard as a normal one?
Would using the hacked keyboard along with a ipac work okay?
Or has anyone got other options? cheers
radiator
  • Last login:April 18, 2013, 07:14:43 pm
  • SFA OK!
    • :: verticalcircle ::
Re:Hacking a keyboard
« Reply #1 on: June 11, 2003, 01:56:21 pm »
use mamewah...
you can shut down the PC from within the FE
or, just re-wire your computers power button to the front of yer cab (all modern PC's normally shut down then switch off when the power button is pressed)
 :P
When the Germans bombed the British, the British ducked.
When the British bombed the Germans, the Germans ducked.
When the Americans started bombing, everyone ducked!
RedSquirrel
« Reply #2 on: June 11, 2003, 02:53:54 pm »
use mamewah...
 :P
ah yes the button would be easier. I did try mamewah but didnt think much of it (couldnt get  it to work right). Ill try again though sometime.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: June 11, 2003, 11:55:53 pm »
or wire your power button.  It's just a switch.  Oh wait, that depends on the mobo.  My roommates mobo will shut windows down then you press the power button.
