Author Topic: Toshiba PB6643 - shakes  (Read 1840 times)
moose
  • Last login:June 27, 2010, 03:03:14 am
« on: September 04, 2008, 02:56:37 am »
I have a Toshiba PB6643 hooked up to a Dance Maniax machine and it's got the shakes. Any vibrations at all (including those caused by the machine's own sound system) cause the display on the screen to wobble. It's not a constant thing and goes away depending on if we whack it the 'right' way or move the cab to a different spot on the floor. What can I do to fix this?
TIA
grantspain
Re: Toshiba PB6643 - shakes
« Reply #1 on: September 04, 2008, 04:07:26 am »
you  probably have a bad solder joint on the monitor chassis somewhere or a bad connector
moose
« Reply #2 on: September 04, 2008, 02:28:05 pm »
Any chance you could be any more specific?
SirPeale
  • Green Mountain Man
« Reply #3 on: September 04, 2008, 03:36:08 pm »
That's already very specific.  Take out the chassis and look for bad solder joints.
« Reply #4 on: September 04, 2008, 03:39:51 pm »
Also check for potential magnetic interference.  If sound is doing it you could be looking at the speakers causing it magnetically rather than through vibrations.
